Old 25th May 2011, 11:13 PM   #1
lduarte1973's Avatar
Question Best Amplifier Sound
In your opinion what type of amplifier sounds best , Class A tube amp or others ?
Old 25th May 2011, 11:16 PM   #2
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
The best that sounded on my breadboards was a hybrid amp, with augmented source followers loaded on counter-modulated current sources. It was a winter-only amp, though... Kind of sounding heater...
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 25th May 2011, 11:19 PM   #3
nigelwright7557's Avatar
Personally I cant tell the difference between AB, A and D.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 25th May 2011, 11:28 PM   #4
Wavebourn's Avatar
The difference is, how well it fools imagination. If you hear a nice reproduction it is Hi-fi. If you hear as if real singers, musicians, waterfall, ocean, etc... in front of you, it is high-end.
Old 25th May 2011, 11:56 PM   #5
like most people i like the sweet sound of tubes , but shouldn´t the best amp be the one that adds less distortion and coloration to the signal ?
i have 2 amps connected to the same tube preamp and cd player , in the arcam delta 290 the sound is " warm " higs seem rolled off , the cambridge audio 740 the sound is " colder " tighter bass , " open " highs , these are obvious colorations from both amps.
Old 26th May 2011, 12:01 AM   #6
Depends on what you are using the amplifier for.
If its for music reproduction then minimal distortion is paramount.
On the other hand of your a rock guitarist then coloration is everything.
Thats why most guitar music shops stil lstock valve amps.
The classis is a Marshall valve amp, loved by millions.
Old 26th May 2011, 12:07 AM   #7
i play bass guitar , those older marshalls like jcm800 are great amps for guitar , a guitarrist i played 14 years ago had one with his gibson les paul it was so good for hard rock.
But i was thinking about music reproduction hifi.
Old 26th May 2011, 12:14 AM   #8
Wavebourn's Avatar
Sure. And tubes are the way to achieve that. Except, not "coloration to the signal", but coloration to the sound. It is controversial, and signal does not have colorations. It has alterations that can be perceived as sound coloration, but can be not. Like, better smoothness of transfer function adds less of sound coloration than better linearity of transfer function, if in order to achieve better linearity we sacrifice smootness.
Old 26th May 2011, 12:17 AM   #9
AKSA is offline AKSA  Australia
WB,
Not to be critical, but how do you draw a distinction between 'smoothness' of transfer function, and linearity of transfer function?
I wrestle daily with these concepts, and I think I know what you mean, but I am uncertain. Are you referring to how quickly the curve changes direction?
Hugh
Aspen Amplifiers P/L (Australia)
www.aksaonline.com
Old 26th May 2011, 12:24 AM   #10
i have my eyes on Vincent Hybrid amps for a while , maybe it´s time i try one !
Observations of amplifier sound bigwill Tubes / Valves 5 30th December 2008 12:18 PM
SE sound from a P-P amplifier smoking-amp Tubes / Valves 34 28th March 2006 03:40 AM
amplifier sound quality keyser Solid State 0 10th February 2005 03:36 PM
Awful amplifier sound, what is it? VvvvvV Chip Amps 2 30th August 2004 12:15 AM
Sound of bridged amplifier Gabevee Solid State 17 23rd July 2002 09:01 PM
Page generated in 0.15140 seconds (67.45% PHP - 32.55% MySQL) with 11 queries
