#881 |
#882 |
I'd like to know more about Class A preamplifier for use with this amp, and I'd also like to know more about Class A nested preamplifier for use with this amp.
Instead of running a high gain power amp, I'd like to explore running a preamplifier gain stage from regulated/capmulti power. If that is a nested preamp arrangement then the super clean signal is propagated globally.
♦ Tools & Guides ♦ ClipNipper headroom boost ♦ Parallel LM1875 pt2pt ♦ Easy parallel TDA7293 board ♦ TDA7294 pt2pt ♦ My post has opinion. |
#883 | ||
Can you give an example of "nested" preamplifier? Quote:
#884 | ||
At the larger scale, it is looking attractive to use a preamplifier run cleanly from regs/capmulti. Having done so, it looks even more attractive to do a nesting preamplifier so that the global feedback loop is run from the preamp that also runs from clean power, thus "copying" the clean from end to end.
#885 |
Daniel, I got two words for ya: Bode Plot.
You can't just randomly cram an extra stage of gain and phase shift into an already optimized closed loop. Won't be stable when you are done. |
#886 |
Not into. Around.
#887 | |||
An independent gain block of 20dB or so is much easier to manage. PS There are cases where an additional feedback path is used to manipulate the apparent output impedance of the amplifier, to suit the speakers, but that's somewhat different
#888 | |
You can have any combination of parts causing any combination of sonic signatures resulting in a great many almost hi-fi amplifiers or you can engineer a constraint to that variety. A preamplifier can have a resistor added from inverting input to the speaker jack of the power amplifier in which case the small amount of added feedback constrains variances. I do have some parameters. Sonic signature variance of Circlophone can be up to 8db, at most. Somehow, that tells the required extent/strength of the nesting loop. At the point of knowing the extent, then the challenge is to install about that much constraint (provided by the preamp) without hindering the stability of the power amp. At end result, it should be possible to get hi-fi on every build without exception, even if someone happened to install a real plonker of an output device. By same factor, the clipping performance will also be cleaner if a case exists where the power amp clips but the preamp doesn't, then the nesting loop will wash clean some of the clip. There you have 3 big jobs done by just one preamp: A gain stage run from super clean power Power amp variance constraint without endless fine tuning/parts swapping Cleaner clip performance
#889 |
An amplifier with an optimized closed loop will have about 150 degree phase shift
at the point it crosses 0db, and probably roll like crazy beyond that point. If you cascade another amp with that, even one that is perfectly linear and adds no phase shift, the combined result will not be stable to close an all-encompassing global loop. You will have to severely overcompensate the nested amps. Preferrably lowering gain to extend bandwidth, than by rolling them off early. Cause its roll that adds to a problem. You can stack the flat part of flat Bode plots to a higher open. But one and only one pole must roll, and far earlier than the rest. You also have to relocate your pre-clip, to get its phase shift out of the new loop. You could not nest amps, both optimized to roll at the usual rate and place in the usual manner... The circlophone's compensation would have to change, as well as the pre-amp. I would not mess Circlophone's proven stability. So easy to make an oscillator... Follow my thread if you want oscillators. I am trying to add a stage of class A balanced, prior to injection of the quadrature feedback. Because balanced A is a candidate for cross coupled neutraliztion of Miller to extend bandwidth. After mixing QFB, you can't do that trick anymore, so I want to mix QFB as close to the output as possible... again, my theories usually make oscillators. I think you would do better to take the +40dB open loop boost offered by CFPs, Set the closed loop to whatever gain suits you, and still come out ahead. Last edited by kenpeter; 1st May 2012 at 11:56 PM. |
#890 |
First the honest disclaimer: I am no technologist to get into the nitty gritty of design. Still I wish to comment on a few points.
Here a new topology has been presented--for the vary first time, so far as my limited knowledge goes-- with a bunch of advantages and flexibility, quite beyond the finicky precision of audio design and setup as most of us know it. Hooray! But I guess in our enthusiasm, we shouldnt "tweak it beyond recognition" and end up with the proverbial camel, which originally was planned as a horse, until the committee decided to chip in with mods and tweaks. No offence meant to anyone, but the collective aim of discussion and debate should be, IMHO, to take the design forward along its declared path and to devise testing methods etc to validate/improve the design. Perhaps some of the more knowledgeable should move to man the rudder! As an enthusiastic follower of the "audible difference" camp, I must perhaps at this point recall the move by many Japanes audio majors towards the quasi-complementary output topology in the late 1970's or thereabouts. Many Japanese amps of the era used custom designed output transistors with large die sizes and large double and triple-sized 'bodies', and many of these were audibly superior to other designs. This was before the craze for "super symmetry" and before the MOSFET invasion. Many of the designers of the time favoured the quasi-complementary output stage with robust NPN devices, and as a result, one of the favourite stunts in our DIY group was to build almost identical power amps, one with fully comlementary devices and the other with a quasi-complementary stage and do some serious listening comparisons. As I remember, the devices of choice were the 2N 3055/2955 series or the 'clones' TIP or MJ series. I still have some of those PCBs in the 'junk box'! Frankly many of us thought (and I still believe!) that the quasi sounded 'better', all said and done. All the greater reason for me to want to jump in and finish the Circlophone, and have a listen! But even before I come to that (thrilling!) milestone, I dare say, Elvee, you are the best that has happened to DIY in a long while, if only it is for the reason that yours is a highly tolerant design and lends itself to implementation by the hobbyist with limited knowledge, resources and test equipment, while at the same time it takes him/her to a higher level of audio 'nirvana' with considerable ease and confidence! |
| Need help with OB design - cheap, cheap, cheap | djn | Multi-Way | 38 | 30th May 2010 06:26 AM |
| Scosche SPL meter: Cheap find with potential, or cheap junk? | theAnonymous1 | Everything Else | 5 | 11th October 2006 03:40 AM |
| Alpine cda-9831 vs. 9833 vs. 9835 | cbecker33 | Car Audio | 3 | 10th December 2004 12:47 PM |
