Old 19th April 2012, 07:35 PM   #871
Elvee is offline Elvee  Belgium
Elvee's Avatar
Originally Posted by The Prof View Post
Trust you dont mind my nitpicking ...
Best regards.
I don't mind in the least: it is an opportunity to hint at what this thread title refers to:
MLCD [My Little Cheap Dictaphone] : The tragic tale of a genius
I hope you don't mind having such a bucket of subculture thrown at you!
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophone© ♫♪
Old 21st April 2012, 02:38 AM   #872
@Elvee
Then perhaps a minor addition like 'My little, cheap Circlophone' ....
Sorry about the 'comic relief' in the middle of serious discussion.
Genius will always be rewarded. Period.
Old 21st April 2012, 04:47 AM   #873
@Elvee
I'm sure Alan Turing would disagree.
Old 21st April 2012, 04:19 PM   #874
Elvee's Avatar
Good fun is one of the most serious and important thing in life, you have no reason to feel sorry.
Old 24th April 2012, 04:41 PM   #875
danielwritesbac's Avatar
I'm curious about the relationship between the driver and output HFE.
For example, a Tip41 (some of them are HFE 15) or MJW18020G output device. . .
And, then there's driver selection:
KSA1220AYS (BD140-16) or 2SA1930 (BD140-8)
Is it true that the high HFE driver will run hotter because of doing more work, and in this case we want to put the higher hfe driver with higher hfe output and likewise put the lower hfe driver with lower hfe output?
For ease in these selections, is there an ideal proportion between driver versus output?
There's been something going on for quite a while and the number of repeatable results samples has added up well enough to say that this is probably not subjective.
Tools & GuidesClipNipper headroom boostParallel LM1875 pt2ptEasy parallel TDA7293 boardTDA7294 pt2pt ♦ My post has opinion.
Old 25th April 2012, 07:57 AM   #876
Elvee's Avatar
The basic requirement for the combination driver+OP is that the product of the Hfe's must be sufficient.
Using basic arithmetic, it is easy to make a quick and simplified estimation: the OP stage has to provide a peak current dependent on the supply voltage and the load: for example, +/-40V and 4 ohm mean 10A.
The VAS has a quiescent current of ~13mA. If we don't want to exceed a 50% imbalance, this means the available current excursion is limited to 6.5mA.
If we divide 10 by 0.0065, we get ~1540: that is the total gain required from the CFP to achieve the target power.
You can distribute that gain the way you want, an obvious method is to take the square root, in this case about 40 for each.
But the dissipation in the driver only depends on the OP's Hfe, not its own Hfe. But of course, if the OP has a low Hfe, the driver will need to compensate for it to meet the above calculation.
Note that the calculation is rather pessimistic: not only can you use the full 13mA of the VAS, but in case it is still insufficient, the bias servo will intervene and raise the average current level to meet the demand. This is why the Circlophone is able to drive obscenely low loads, but the linearity is somewhat degraded in those conditions.
The proportion itself is not important, provided the global Hfe is sufficient. What is important is the linearity of the Hfe vs. current.
The combination driver+OP has to be as flat as possible, this will in general mean that both the drivers and OP are flat themself, although some compensation of non-linearities would be in theory possible (although difficult to achieve in practice)
Old 25th April 2012, 03:54 PM   #877
Let's see if I understood.
It is a current function.
Any excess driver gain serves like a spare tire--When the op gain drops when/because it is delivering more or even peak current, the driver makes up the difference only during that condition. And we don't want that to be abrupt.
If the op is poor, with a fluctuating shift, the op's sonic signature is heard during low volume playback, but when the op falters, the drivers kick in much harder with abrupt change to class a tones for high volume playback and dynamics.
or
If the op is good, with a level behavior, then the "hand-off" is gentle and transparent, with a well balanced sonic signature, and the intended function of a Circlophone. Oh, that OP short-list was important, wasn't it?
P.S.
If someone really wants parallel outputs, it seems they should consider matching some MJW18020G.
Old 26th April 2012, 07:19 AM   #878
Elvee's Avatar
or
It is a picturesque description, but that's about it.
The OP transistor type is decisive, it is the single component having the most effect on the quality of the amplifier.
Note that the "original" Circlophone has been completely tested and characterized with 2N3055's, and it isn't bad. But it can be even better with better transistors.
P.S.
Matching is a luxury, but it can help. It also allows for absolute minimal degeneration resistors, which is a good thing.
Old 26th April 2012, 03:09 PM   #879
Maybe true for EF outputs, I dunno about that statement for Circlophone.
OP is the VAS and slowest stage, quite possibly an advantage for stability.
You really need all transistors aside from VAS to be in stable local loops
with much higher knees. And that's the challenge. Else you are having
to sandbag even the best VAS transistor down into the audio band to
avoid an overlapping phase shift.
For stability, open loop gain often wants to roll just above 1K. Does
not hurt closed loop performance at or below 1K. But everything to
be heard above the open knee is far less correct. And this is no fault
to blame an OP transistor, especially if you are forced to add CDOM
to stabilize. But we prefer this knee should be well above audio.
Any OP VAS with natural knee above 20K will do. What goes before is
what determines how much open loop bandwidth can be made stable.
Why Circlophone should do extremely well even with 2N3055.
Old 26th April 2012, 04:57 PM   #880
Elvee's Avatar
I was talking mainly in the context of linearity, Hfe flatness versus collector current, not dynamic characteristics.
But the bandwidth will also play a role. If the OP are too slow, the drivers will need to provide larger current excursions to drive them properly.
Need help with OB design - cheap, cheap, cheap djn Multi-Way 38 30th May 2010 06:26 AM
Scosche SPL meter: Cheap find with potential, or cheap junk? theAnonymous1 Everything Else 5 11th October 2006 03:40 AM
Alpine cda-9831 vs. 9833 vs. 9835 cbecker33 Car Audio 3 10th December 2004 12:47 PM
Copyright ©1999-2013 diyAudio
