♫♪ My little cheap Circlophone© ♫♪ - Page 69 - diyAudio
Old 18th February 2012, 07:41 AM   #681
danielwritesbac's Avatar
I would really like to discuss regulated power supply for Circlophone, especially since the Philips BD140 gets sketchy at higher voltage and is vulnerable to power surges if run unregulated. But that's just an excuse. Regulated power has a different sound, usually a great quality baritone region, and I'd like to try that. Capmulti can do the same, but I don't have an excuse to ask for that.
Old 18th February 2012, 11:17 PM   #682
terranigma's Avatar
Originally Posted by Elvee View Post
I didn't care to make the rest of the modifications, and connected it to a source and speaker: as I write, I am listening to it and everything seems OK
CFP version hasn't zeners in scheme (I don't know why). Were they in place when you testing?
Old 18th February 2012, 11:30 PM   #683
The zeners can range from total voltage span (no zeners present) to half of total voltage span (as shown in post 1 and post 658). The difference is apparently heat in one of the drivers. And you want to use the zeners. I guess and predict that he will answer yes, he was using the zeners, as shown in post 1.
What I'm unsure of is the connection of the R18+C12 RC when the zeners are installed (and they should be). It appears that the RC is for assisting the drivers, which is not exactly what the schematic (post 1 and post 658) shows since the RC may be less effective when isolated by those diodes. So, I'd like to add that question. Should the RC go directly between the divers instead, for post 1 and likewise post 658?
Old 18th February 2012, 11:47 PM   #684
terranigma's Avatar
Another thing is, I'm not sure that is it safe without D10,D11 and C3 in a real circuit. I want to try CFP version and I'm trying to modify powerlux pcb respecting CFP scheme.
Old 19th February 2012, 12:56 AM   #685
I was investigating how easily one could fudge an undervoltage lockout.
In case one power supply is up, the other not (fuse blown or whatever).
Amazingly, I find circlophone needs none! You can disconnect either
supply from it's rail, and nothing bad happens. Accident of genius?
It also tolerates the case of positive supply shorted to GND.
Does not, however tolerate the negative supply shorted to GND.
What would it take to make that condition safe too, just a diode?
Old 20th February 2012, 09:13 PM   #686
terranigma's Avatar
Has anyone any idea of possibility of degrade something if using relatively high gain transistors as input pairs in CFP version? Mine are BC560C (~540) and BC550B (~380).
Old 21st February 2012, 07:51 AM   #687
Elvee is offline Elvee  Belgium
Elvee's Avatar
No, that shouldn't cause any problem. It will make the input resistance even higher.
. .Circlophone your life !!!! . .
Old 22nd February 2012, 11:14 PM   #688
Default Nice power supplies?
I'd like to hear about some deluxe power supply options for both regulated and unregulated power that are really good with Circlophone.
Of course Circlophone does perform well with a really basic power circuit, and although that is true, I am curious about clean power, and I am especially curious about decreasing the harmonic influence of the power supply, by using a clean / higher quality power supply.
Old 23rd February 2012, 11:58 AM   #689
Elvee's Avatar
Like most decent amplifiers, the Circlophone needs no regulated power.
At best, a regulated power supply will not change anything, but in most cases (that is particularly applicable to "audiophiliacs" supplies), it will do some harm, because of an uncontrolled output impedance or downright instabilities, like in this example.
I guess this one must seriously "enrich" the harmonic balance of whatever it supplies:
Old 23rd February 2012, 02:37 PM   #690
If the amplifier is dead quiet at idle, prevented from clipping,
drives all stages entirely by high impedance currents rather
than low impedance voltages: When would it be interacting
with reasonable amounts of low frequency power supply ripple?
This is painting "enable" dots on the edge of a CD. The last
resort of someone with far too much time on their hands.
I see a lot of "simple" amplifiers that want 4 or more complex
supplies of absurd cleanliness. I don't perceive any advantage
designing amplifiers to lean upon a crutch of such requirement.
Need help with OB design - cheap, cheap, cheap djn Multi-Way 38 30th May 2010 06:26 AM
Scosche SPL meter: Cheap find with potential, or cheap junk? theAnonymous1 Everything Else 5 11th October 2006 03:40 AM
Alpine cda-9831 vs. 9833 vs. 9835 cbecker33 Car Audio 3 10th December 2004 12:47 PM
Copyright ©1999-2017 diyAudio
