#621 | |
Probably, the 6db more from the speaker difference between my 45w amp versus a 150w amp, should not require a large increase of gain to facilitate that difference. I do not know, but it seems that we could decrease the 470R very slightly and perhaps use matched BC560C at input to enhance capacity for gain? (not shown) A version of Ken's soft clip device, replacing R16, with 325R,145R divider (plus, in real application, to decrease current, an additional 470R between "wiper" and diodes) does seem to work quite well and is worth an interview. It seems especially suited to a high gain amp (integrated amp), to help constrain momentary conditions. (not shown) I also added ---|<---->|--- zener stopper parallel with the 10k input load. This is extremely helpful. It doesn't do much for most of the time, but sometimes it blocks crazy (source selector dial and/or computer startup, power saver cycling) and it does its job well. It is capacitive and blocks RF too. That is also worth an interview. The schematic in post 1 is really great, but documentation has more questions to answer. Parts availability and easier shopping is the primary motivation of the schematic below. It is easier to read than pagefulls of posts. I hope the D7 and R21 sections are suitable? If the power amp schematic below is okay, then I could proceed to page 2 of the documentation for Circlophone options and accessories. For the second page (accessories and options) it seems really nice to start out with jfet buffer accessory if that is doable? Last edited by danielwritesbac; 6th February 2012 at 08:11 AM. |
#622 | |||||
You can have some excess gain and leave the volume control half-way. That's no rocket science, there is no influence on "dynamics" or temperature or anything: controlling the overall gain by whatever method yields identical results (within reason obviously). Quote:
Converting those variations into resistance is meaningless. Quote:
You have two signal superposing there: the regular, differential, that would normally cause equal and opposite variations in the transistors, like any other LTP, and the common mode signal which reinforces whichever side is "positive", and cancels the other: the bias is continuously sliding, twice per cycle. You can see this waveform in R1's current for instance. R1 has very little effect on the differential mode: it simply form a Tee attenuator with the two re's of the transistors, but since at that current, the re's are much smaller, the effect is very small. In addition, the drive is balanced, which further contributes to eliminate any effect. But on the contrary, R1 directly dictates the common mode gain (transconductance). Making it 0 is not impossible, but it would make one's life very difficult, because the common mode gain is already more than sufficient, and increasing it unreasonably would require very good compensation. Quote:
#623 |
I apologize for asking, are BAT85 (30V) and BAT47(20V) suitable for D7 with 31V supplies? Does D7 share Vs or 2xVs with 1N4148 or regardless with Vs? My working setup is on the shelf by now and I can't measure voltages just for a while.
I found NOS 2N5858's at a local supplier and bought 10 of them.
#624 |
#625 |
Both are suitable.
None of the diodes in this amplifier has any reverse voltage applied (except for the zeners, of course).
#626 |
#627 | |
In fact, this could be compared to the functioning of a parametric amplifier (it is one actually): one parameter of the amplifier is modulated at twice the rate of the carrier by a pump frequency. The pump frequency does not directly contribute to the output, and if it is applied alone, no output signal is generated. Here, the pump signal is generated by the common mode loop. In order to keep the normally inactive half of the amplifier at the threshold of activity, the general operating level is raised, which results in a doubling of the amplitude for the active part. In a conventional amplifier, the inactive half goes into deep cut-off, and does not contribute to the output, because transistors are unidirectional devices, and can only source or sink current. It is because of this diode-like non-linearity that the pumping process can take place and provide gain: in a pure class A amplifier, it would simply modulate the standing current, but would not provide any supplement of gain. The modulation reinforces the action of each active half in turn. For this effect to happen, one must have a means of modulating the current: here, it is the common-mode voltage combined with R1, but it could as well be a CCS controlled by the bias servo; that is an alternative method to create a Circlophone. Here, the parametric amplifier mechanism is not the main purpose, it is just a side effect of the servoing method.
#628 |
I think Daniel means that could we get similar affect like Elvee's new CFP implementation if using aka 700 Hfe LTP transistors rather than 250 Hfe ones. I may wrong but it sounded like me that.
#629 |
Generally those super high betas come in NPN flavor only.
But worse to invert the whole circuit and make output PNP. You can drop or add a stage, to make in and out both NPN. I think this guarantees a detriment to either gain or stabilty. The existing compromise is pretty good, but you can always mess it up if you dare. |
#630 | |
The added jfet buffer is one way that I could ensure that the amplifier performance remains more likely constant between sources and not have me unnecessarily troubleshooting for a very long time like a puppy chasing its tail until dizzy. Help! How do I install this jfet? Could you provide a schematic example of how to install the jfet to the Circlophone at post 1? I believe that the added part will help promote reliably repeatable results as well as greater compatibility to various sources of which there is vast variety. And, that variety needs tamed a bit. Jfet buffer? P.S. At that point, the very next question would be ideal specs for jfet shopping.
| Need help with OB design - cheap, cheap, cheap | djn | Multi-Way | 38 | 30th May 2010 06:26 AM |
| Scosche SPL meter: Cheap find with potential, or cheap junk? | theAnonymous1 | Everything Else | 5 | 11th October 2006 03:40 AM |
| Alpine cda-9831 vs. 9833 vs. 9835 | cbecker33 | Car Audio | 3 | 10th December 2004 12:47 PM |
