♫♪ My little cheap Circlophoneİ ♫♪ - Page 26 - diyAudio
Old 6th September 2011, 06:36 AM   #251
Nope, I'm not offended. Hope you're not offended.
I blame Bigun. No reason, it just feels so right...
Was not my intent to pass off phoney circlos...
Just trying to clarify a circuit that I difficulty
wrapping my mind around. It was several days
before I even realized that it performed the
same computation I had been working on...
Old 6th September 2011, 06:02 PM   #252
Elvee is offline Elvee  Belgium
Elvee's Avatar
No problem, I think each of the two approach has its own merits, and there is room enough for both.
I suspect your version will appeal more to a number of members of this forum: it is more straightforward, and doesn't include a rather complex servo loop, as the Circlophone.
It is true that in a more complex system, there is more space for things to go wrong.
I took great care in ironing out any potential issue, I tried to leave no stone unturned (or maybe the opposite) to make sure the thing is 99.99% reliable.
But many won't trust the system and will prefer your way of doing things.
I cannot blame them, and generally I prefer this kind of topology too, but I found no way to achieve my goals without adding some complexity.
The result is not very elegant, but it is astonishingly effective, and so far it looks foolproof.
. .Circlophone your life !!!! . .
Old 6th September 2011, 10:57 PM   #253
terranigma's Avatar
Thank you Elvee for sharing with us this beauty. I always respect to intelligent potential and kindness spirit of this site.
I'm planning to build this amp as four channels due to my active speaker requirements. As normally, I'm using balanced signal for each channel. Has circuit any potential to modify input stage to accept balanced signal without referencing to ground? If no, that is not so important at all.
I like to use oldschool parts in new designs, especially TO-3 ones. I got plenty of devices like:
Motorola 2n3773 (Vcbo=160,Vceo=140)
Toshiba 2sd110 (Vcbo=130, Vceo=110, 1mhz, 200pF)
Motorola MJ15003 (Vcbo=140,Vceo=140, 2mhz, 1000pF)
Motorola 2n3055
I think it is easy to maintain 80-100W with a pair of these using proper driver transistors and rails.
I got some choices of DC rails like: 31V, 36.5V, 62V. I think 36.5V a bit low for 80-100W range. As you mentioned in post 182, 31V rails are enough to get 50W. Maybe i have to go with it if I can't bear build a LM338 based regulator for drop 62V to 42V.
Regards.
Old 6th September 2011, 11:31 PM   #254
Don't think its that complicated, just needs a well commented redraw of the schematic.
I could take a crack making it easier to read. You want to post latest known good .asc ?
No design changes, just a re-draw....
Old 7th September 2011, 01:43 AM   #255
Bigun is offline Bigun  Canada
Bigun's Avatar
what ? me ?
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 7th September 2011, 02:15 AM   #256
Here's a sample redraw, based upon Circlophone M.
Models are all still there, just above the screenshot.
During the redraw, I have come to question R19's
purpose? Appears only to bias Q12 into saturation.
Its exactly like this in the original, so I have to ask.
Was this an oops? Intended as a base stopper???
I haven't commented any part of the circuit yet.
Old 7th September 2011, 02:29 AM   #257
Bigun's Avatar
I think I asked the same question, only it was R14 when I asked it...unless I'm confused the explanation is here:
Old 7th September 2011, 02:42 AM   #258
PSRR fix for Q12, got it...
I didn't change any reference designators, by the way...
Looking back, the original Circlophone drawing wasn't bad.
It grew slightly less organized as it evolved...
Old 7th September 2011, 12:08 PM   #259
Elvee's Avatar
Using the (-) input of the amplifier seems risky, as the source impedance would influence the feedback.
This could lead to problems, and I would not recommend it.
If you can be a bit patient, the next PCB version will include a preamplifier with a balanced input.
It is being finalized, and should be available soon
Motorola 2n3055
They are all suitable, and if you aim at 100W the MJ15003 seems perfect.
You don't need other drivers, some of the other transistors may need a higher Vceo if you go for 42V rails.
The original drawing is purely graphic, and didn't evolve. The functional versions are messier.
You did a nice cleaning job, thanks for the effort.
Anyway, here is the asc of the graphic version, if someone wants to play with it.
Old 7th September 2011, 10:33 PM   #260
terranigma's Avatar
My concern is C3, coupling cap at input. My source has DC if it refers to ground, thus requires a cap at input of amplifier which is a compromised solution that I dislike -imho-. If I use balanced as source, then there is no ground referenced signal and there is no DC, then there is no need a cap in signal path. It is fair enough to put a speaker protection at output for possible failures.
I'm a lazy builder, then there is no hurry for me
Regards.
PS: If you ever build/listen an amp based on LME49810's.. can you compare them?
Need help with OB design - cheap, cheap, cheap djn Multi-Way 38 30th May 2010 07:26 AM
Scosche SPL meter: Cheap find with potential, or cheap junk? theAnonymous1 Everything Else 5 11th October 2006 04:40 AM
Alpine cda-9831 vs. 9833 vs. 9835 cbecker33 Car Audio 3 10th December 2004 01:47 PM
Copyright İ1999-2017 diyAudio
