♫♪ My little cheap Circlophone© ♫♪ - Page 121 - diyAudio
Old 4th May 2013, 12:14 PM   #1201
abetir is offline abetir  Philippines
^Thanks!, I have etched the board i will be populating it soon... The objective is to create another compact board yet avoiding vertical mounting (especially the resistors).
I have found a Class D type heat sink (aluminum bar) which perfectly matches the space provided for it for the VAS. I just hope this new design will work smoothly...
Regards!
Old 23rd May 2013, 01:27 AM   #1202
Here is the bottom copper for toner transfer etching for post #1199 lay-out,
TY!
Old 5th June 2013, 10:31 PM   #1203
Flibble is offline Flibble  United Kingdom
Flibble's Avatar
Default Thanks Elvee and abetir!
abetir - I etched and built your board up, layout is great and works perfectly! I built the board on very minimal budget with what I could find on ebay Q12/Q13 are 2SC2240, Q5/Q6 are 2SC3421, D3/D4 are 10SQ045. One minor issue is that the BD140s are getting very hot and I suspect they are fakes . The heatsinking in the pic is just for testing.
Cheers, Dan.
Old 6th June 2013, 01:11 AM   #1204
Excellent Dan!
..pretty clean build from the looks of it the BD140s could have been fakes (not so sure though ), original phillips are gray in color and I guess they are becoming very hard to obtain. I see you are using metal cans for the output, also put a heatsink on VAS any small type (or DIY) should fit nicely on the space provided. I'm glad it works!
Just be sure to follow the power chart table.
Thank you Dan.
Old 6th June 2013, 07:55 AM   #1205
Elvee is offline Elvee  Belgium
Elvee's Avatar
Originally Posted by Flibble View Post
One minor issue is that the BD140s are getting very hot and I suspect they are fakes.
It is normal the BD140 become hot, they dissipate a significant quiescent power, and that is true whether they are fake or not.
Yours are certainly not original Philips, but that doesn't mean they are actually fakes: they could be from Telefunken, Siemens, ST, Motorola, etc
. .Circlophone your life !!!! . .
Old 2nd July 2013, 10:18 PM   #1206
Flibble's Avatar
Default Well chuffed...
abtir, Elvee - I think you were right about my original ST BD140s being genuine (I was suspicious of the very neat printing and shiny legs, in addition to the fact they were from China and very cheap ). I ended up replacing them for NOS scruffy grey Philips ones I found anyway. Thought you might like to see my finished boards, the BD140s are bolted to aluminium box section and the boards stand off. Still need boxing up (each assembly is one side!) but I'm listening to them now and I'm very happy
Old 3rd July 2013, 11:20 AM   #1207
Elvee's Avatar
Nice build!
Old 6th July 2013, 03:29 AM   #1208
flibble, very nice heatsink works!
Old 16th August 2013, 04:03 AM   #1209
very good
Old 7th November 2013, 09:09 AM   #1210
Elvee's Avatar
Here are some fresh news from the front:
Member Piersma has developped his own "deluxe" version of the Circlophone: it uses a cascoded jFET input stage amongst other improvements, and offers better overall performances at the cost of a manageable increase in complexity.
It still retains the basic Circlophone principles, meaning optimal sound quality without adjustments or thermal problems.
Sjerko has kindly sent me two boards for evaluation, and after some minor adjustments of the compensations, they work beautifully.
This version is therefore ready to be built and tested by others.
I'll let Sjerko himself present his work and material.
Need help with OB design - cheap, cheap, cheap djn Multi-Way 38 30th May 2010 07:26 AM
Scosche SPL meter: Cheap find with potential, or cheap junk? theAnonymous1 Everything Else 5 11th October 2006 04:40 AM
Alpine cda-9831 vs. 9833 vs. 9835 cbecker33 Car Audio 3 10th December 2004 01:47 PM
Copyright ©1999-2017 diyAudio
