Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Solid State Talk all about solid state amplification. |
#561 | ||
That's the path I tried to follow for months, when I was developing the Circlophone: it seemed natural and logical, and avoided the saturation issues of the other option. I could arrive at extraordinarily good static or quasi static results, but the dynamic behavior was a nightmare. In the end, I gave a try to the dual version, and miracle: the dynamic problems were gone. There was a degradation in the static linearity, but it was acceptable, and the Circlophone was born. Now, I am not saying all systems based on the lack of current are doomed, I have made successful attempts in the opposite direction, but for some reason I don't grasp, the "positive" variant seems more responsive Quote:
Interesting, but I fail to see the advantages of this configuration: ideally, we are looking for an optimum differential gain and linearity, and a minimal interaction between common and differential modes.
#562 |
Evequad what I has in mind, more or less?
Anyways, yes it works. No, not any better. This might have been worth exploring, but I am ready to concede it is not fully baked. Weird thing here: Gain is max when emitter resistors (and diodes) are abused up top, to match the ones on the bottom. Not just the distortion goes down, open gain goes up!!! Bigger or smaller resistors lose gain, why? But open loop gain here is not comparable to a plain old xquad, nor even the CFP way. This Evequad seems only just barely gainful enough to get the open loop job done, and I don't really understand it well enough to know what stability means in this contex. Last edited by kenpeter; 29th January 2012 at 02:32 AM. |
#563 |
Another iteration of powerflux pcb ...
#564 |
Bandwidth is up, and behaving well for both reasonable
(soft clipped) and unreasonable (hard clipped) overloads at the input. Both input transistors stay on til the clipping nonsense gets way beyond even that... I was just trying to keep these transistors on, when I noticed a problem with diodes from input to output... If you don't attenuate that feedback, it can be mis- interpreted as a positive and aggravate the clipping, maybe even latch.... Give it anything less than unity, and the problem does not occur. So basically, anytime the output can't properly follow the input, the input is attenuated to a smaller copy of the distorted output. Prevents all sorts of wacky evils when faced with the impossible. Thats when I got this dumb flash that maybe this is also where my comp should go? YESSS.... that worked! Finally could loosen the screw on those output transistors. 40KHz lookin' siney with just a little bit of triangle, and tips not bent (phase shifted?) too much forward nor back. |
#565 |
More foolishness from the same bag...
Drop either rail to 12V and watch it shut off. --- Do you ever get the impression that an amplifier trying to play music is like a guy at the hardware store trying to juggle an egg with vice grip pliers? Last edited by kenpeter; 29th January 2012 at 06:37 PM. |
#566 |
I powered up new pcb but it shows 300mV level dc-offset. If I bypass input cap and shortcut input to ground, It is falling to 50mV level and decreasing to 1mV slowly in a minute. But starting to increase again just after. I have no idea where to look at. Any advice please?
#567 |
Here some voltage measurements referring to ground.
#568 |
Looks to me: 7V too much Zener, or 7V too little power supply?
You could try a cascode at output potential, rather than a zener. Q5 Q6 won't have any excuse to see different collector voltage. D10 or D11 might be faulty? One of your thresholds is maybe higher than the other? Why is there only .1V drop across Q7? Last edited by kenpeter; 30th January 2012 at 01:40 AM. |
#569 |
#570 | |
Regards. Last edited by terranigma; 30th January 2012 at 03:54 AM. |
Thread | Thread Starter | Forum | Replies | Last Post |
Need help with OB design - cheap, cheap, cheap | djn | Multi-Way | 38 | 30th May 2010 06:26 AM |
Scosche SPL meter: Cheap find with potential, or cheap junk? | theAnonymous1 | Everything Else | 5 | 11th October 2006 03:40 AM |
Alpine cda-9831 vs. 9833 vs. 9835 | cbecker33 | Car Audio | 3 | 10th December 2004 12:47 PM |
New To Site? | Need Help? |
