♫♪ My little cheap Circlophoneİ ♫♪ - Page 39 - diyAudio
Old 30th December 2011, 07:09 PM   #381
terranigma is offline terranigma
terranigma's Avatar
Originally Posted by heinz View Post
The only problem i am experiencing: The driver Transistors and 2n3019 are getting too hot to touch. Did anybody else a build usind the tight packed powerflux pcb? Is there a clever way to use a heatsink on the to-39 package?
Thank you.
I built a pair of same pcb, yes 2n3019's are hot but it is not a indicator of any fault. Heatsinks are hot too.. you have to attach a small piece of heatsink at least, rather using them naked.
I will post pics of my current setup soon.
@Powerflux
Can you prepare an alternative version respecting my suggestion related with power rails route and pads?
Old 30th December 2011, 07:21 PM   #382
powerflux is offline powerflux  Netherlands
@Powerflux
i could, but since it it such a minor modification, some graphical editing with MSpaint like in your example should be sufficient and faster than me and eagle printing PDF's...
Old 30th December 2011, 09:20 PM   #383
Elvee is offline Elvee  Belgium
Elvee's Avatar
i made a circlophone based on powerfluxes pcb (see the attached picture). I did use the transistors originaly proposed in the schematic. Voltage ist +-25V.
Power draw (no signal) from Transformator is approx. 10W.
That's normal: this is "warm" class AB (sort of)
If there are no resistor inversions or mistakes, the power in each transistor should be ~25V x 13mA = 325mW.
Since the Rth(j-a) is 219°C/W, this means the junction is 71.18°C above ambient.
For 50°C ambient, this translates into 121.18°C junction temp, or, taking into account the Rth(j-c) of 35°C/W, a case temp a little under 110°C.
Probably too hot to touch for many people, but not a concern: this is not a plastic case, and whilst it would be unwise to operate near the 200°C abs max rating, temperatures below the eutectic (~170°C) are perfectly safe in the long term.
If you feel uncomfortable with such temperatures (it is completely output-power independent), there are small tube or chimney-like TO39 heatsinks compatible with Powerflux's design.
You can also use alternative transistors having a Cob <15pF and Ft>75MHz (do not exagerate in that direction though) like the BF819: the TO202 acts as an integral cooling clip.
BF458 and many other are also suitable, but they are more or less obsolete.
Anyway, you can leave your 2N3019's as they are: there is no risk or problem, even in the long term.
Just make sure the resistors are OK, and the zeners have the right voltage and are not shorted.
PS:
the proximity effect of the transistors increases the apparent temperature, but at supply voltages of 25V, this is not a concern.
None of my prototypes has heatsinks fitted, the transistors are almost as close as in Powerflux's PCB, and one of them operates at 40V
. .Circlophone your life !!!! . .
Old 30th December 2011, 10:26 PM   #384
terranigma's Avatar
Heatsinks are hot too.. you have to ...
What? I meant "Drivers", not "Heatsinks" of course.
Old 31st December 2011, 03:45 PM   #385
Elvee's Avatar
Here are two examples of cooling clips for TO5/TO39.
One is a very small, tube-like shape. It could be used in any situation, even where there is very little space.
It is marked "THM 1115" (probably Thermalloy).
The other is a corrugated, chimney-like, and is more obtrusive.
Between these two extreme, one can also find medium-sized grooved cylinders.
I have no example to display unfortunately.
Old 31st December 2011, 07:25 PM   #386
danielwritesbac is offline danielwritesbac  United States
danielwritesbac's Avatar
Can NXP BCP53 be used instead of the discontinued Philips BD140, or will the modern version not handle the heat? I can't find a TO220 with specs like that.
Old 31st December 2011, 08:17 PM   #387
kenpeter is offline kenpeter  United States
BD140 are still made in TO126 by: Fairchild, ST, and OnSemi. Probably others too.
Old 31st December 2011, 08:28 PM   #388
mickeymoose is offline mickeymoose  Canada
This is the heatsink I used:
Edit: I replaced the MJE15031 (see Elvee' next post) with the 2N3019 in this setup. I am still looking for a suitable transistor in a TO220 or similar package. E
Old 31st December 2011, 08:30 PM   #389
Elvee's Avatar
I am afraid not: even with 25V rails, the quiescent dissipation is already ~=1W, and the dissipation is heavily output-power-dependent.
That's too much for BCP53.
But even if you exclude "newer" BD140's, there are numbers of TO126 alternatives: some 2SAxxx, and 2SBxxx, I think OdysseyBmx opted for one of those, I'll be able to give you some more details next year....
Mickeymoose has based his version on MJE15031 (TO220). That's heavy artillery, but it works provided the VAS is not too oversized: when you combine slow and/or high capacitance VAS + drivers, stability issues begin to appear.
There will be a fix in Mickey's final version, but the simplest option is to use adequately-sized devices for the job.
Old 31st December 2011, 09:41 PM   #390
wait. BD140 discontinued?? seriously?
those transistors are beauties..
Need help with OB design - cheap, cheap, cheap djn Multi-Way 38 30th May 2010 06:26 AM
Scosche SPL meter: Cheap find with potential, or cheap junk? theAnonymous1 Everything Else 5 11th October 2006 03:40 AM
Alpine cda-9831 vs. 9833 vs. 9835 cbecker33 Car Audio 3 10th December 2004 12:47 PM
Copyright ©1999-2017 diyAudio
