Old 20th December 2011, 03:23 PM   #371
mickeymoose is offline mickeymoose  Canada
ELVEE:
Thanks for your patience in getting all of us this far with this amp!
Some additional info :
The board was designed to fit a DIN standard card-frame, size 100x160mm, the assembly is 1.8" wide
I will post schematics and layout info soon
All parts used are through-hole and standard, off-the shelf
If there is enough interest in a group-buy I see following parts included in the package:
2 pc boards (amp & back-plane), heatsinks (4 pcs.) and a programmed uP for the fan
E
Old 20th December 2011, 05:26 PM   #372
Elvee is offline Elvee  Belgium
Elvee's Avatar
Thank YOU for your dedication!
Here are some more pics of the "innards" (always the prototype of the beta version):
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophoneİ ♫♪
Old 21st December 2011, 01:56 AM   #373
gannaji is offline gannaji  India
mickeymoose:
Please count me for one full stereo set!
gannaji
Old 21st December 2011, 07:57 AM   #374
harrydg is offline harrydg  Belgium
Send a message via ICQ to harrydg Send a message via MSN to harrydg
depending on the price: check!
ps. Elvee, greetings from Etterbeek!
Old 21st December 2011, 09:17 PM   #375
The cost of the "kit" depends on what you expect. The easiest for me (and cheapest for you) is just the boards and pre-cut heatsink parts (drill your own holes), it is diy audio, after all. The code for the fan controller will be available (not yet written, any one willing to do that?)
Cheers, and lots of presents to all! E
Old 21st December 2011, 10:19 PM   #376
odysseybmx414 is offline odysseybmx414  United States
Mickeymoose, what outputs are you using?
Old 21st December 2011, 11:42 PM   #377
o...414: I did not change elvee's circuit at all. I used TIP3055 (instead of 2N3055) to acomodate the mechanical constraints. E
Old 22nd December 2011, 07:16 AM   #378
for me it's all the same actually.
I'm getting some symasym boards in a few days and that will be my first. So i dont have any experience in all the diy stuff. So I'll have to buy a hole-maker and all, but hey... i'm gonna need it anyway, so i don't care!
ps. isn't it "safer/easier" do use transistors to drive the fans instead of a micro controller? something like this, but with a thermistor or so to regulate:
Simple Linear Fan Controller
Old 30th December 2011, 05:13 PM   #379
heinz is offline heinz  Germany
i made a circlophone based on powerfluxes pcb (see the attached picture). I did use the transistors originaly proposed in the schematic. Voltage ist +-25V.
Power draw (no signal) from Transformator is approx. 10W.
First impression (using cheap speakers): Good bass and mids.
The only problem i am experiencing: The driver Transistors and 2n3019 are getting too hot to touch. Did anybody else a build usind the tight packed powerflux pcb? Is there a clever way to use a heatsink on the to-39 package?
Thank you.
Old 30th December 2011, 05:31 PM   #380
powerflux is offline powerflux  Netherlands
Thank you.
i've made a mistake: 15R and 56R on bottom BD are reversed on silkscreen. this has been noted before but here i've uploaded a corrected PDF-document.
Other improvements are more space for cooling for the BD's. if one doesn't use the jumper, or solders one on the bottom, one can use a flat standing piece of aluminum across the PCB for both BD's together. but do remember to use isolation (mica or silicone)
i call this V2.0, and the power transistors are TO-264
Need help with OB design - cheap, cheap, cheap djn Multi-Way 38 30th May 2010 06:26 AM
Scosche SPL meter: Cheap find with potential, or cheap junk? theAnonymous1 Everything Else 5 11th October 2006 03:40 AM
Alpine cda-9831 vs. 9833 vs. 9835 cbecker33 Car Audio 3 10th December 2004 12:47 PM
Copyright ©1999-2017 diyAudio
