Old 3rd November 2011, 10:52 AM   #311
Elvee is offline Elvee  Belgium
Elvee's Avatar
Originally Posted by powerflux View Post
like this? i really dislike the way the drivers are routed. there is only space for the tiniest decoupling caps..
I am not too concerned about the drivers, but the way C9 returns to the ground is a problem: it loops back more or less randomly through the input section, and this is going to cause troubles.
The best solution would be to push the big schottky's D4 & 5 towards the center of the board and place the decouplings on the outside, near the edges.
Alternatively, as a second best, it is possible to choose a better return path for C9, without modifying the placement of components.
See pic.
It is also important to define a power and output ground clearly, where the Zobel also has to return: mainly to the right of the board.
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophoneİ ♫♪
Old 3rd November 2011, 07:48 PM   #312
terranigma is offline terranigma
terranigma's Avatar
If we concern the route of current flowing from supply pads, I think that C8 and C9 are not visible to the circuit. Supply pads should see these caps prior to the whole circuit. V0.4 pcb with free soldering option is more attractive in my opinion.
Old 4th November 2011, 04:07 AM   #313
Bigun is offline Bigun  Canada
Bigun's Avatar
Originally Posted by odysseybmx414 View Post
... I hear the Circlophone, and I have more detail in the music than I have ever heard, and I am talking about songs I have been listening to since I was a kid. On top of that it is so musical and "sweet" than I always want to switch it on and play music, even in the most inappropriate situations.
This is a great endorsement - and I remain attracted to the sheer ingenuity of this design. My 2N3055's are still waiting unused for me to finish other projects but I shall be keeping an eye on this Circlophone
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 4th November 2011, 12:25 PM   #314
powerflux is offline powerflux  Netherlands
i'll just enlarge the PCB a bit, that's the best way to fix these issues
Old 8th November 2011, 12:42 PM   #315
boyet0173 is offline boyet0173  Philippines
Hi powerflux,
I really appreciate your effort on this circuit..any update of your pcb layout? Thank you..
Boyet
Old 18th November 2011, 05:41 PM   #316
a quick one. forgot about this project since i'm buisy with an I/V converter.
let's call this 0.6.
- enlarged PCB a bit
- fitted caps
now i want to get rid of the whole groundplane on the left side and just route on specified path back. opinions?
EDIT: like this. 0.7
Old 18th November 2011, 06:20 PM   #317
if the groundplane-one is preferred, here is an update
0.6A
Old 18th November 2011, 08:34 PM   #318
Elvee's Avatar
This time, I think it is about OK. I would just change the placement of the power and output ground pads to eliminate the effect of the class B current from the positive side, but otherwise it is good, and this applies to all versions.
The ones with the complete ground plane are more risky, less deterministic: they might very well outperform the plain boring single ground ones, but I cannot tell for sure.
Any version will perform acceptably.
Some refinements would still be possible to minimize induction effects from the outputs currents, but the improvements gained would be below the current level of performance of the amplifier, and a proper dressing/placement of the wiring would give similar results so I think we can leave it there.
Old 18th November 2011, 09:37 PM   #319
printed PDF's, filled in the componentvalues. i really hope i didn't make mistakes. thank you for your patience
Old 23rd November 2011, 12:14 AM   #320
terranigma's Avatar
Default My dirty setup
At last I finished and listened one channel. I have modified wakibaki's pcb respecting 2sa/2sc small signal transistors. During populating parts, it was not easy to deal with narrow headers and bridges.. just needed some patient.
My setup:
2sa970 as PNP small signal
2sc2240 as NPN small signal
2sa1930 as Driver
2N3442 as output (test setup)
2N3020 as bias servo
180pF as C12 (servo compensation)
1200pF as C6 (main compensation)
31V per rail
Unbalanced signal
After sure that there is nothing wrong with dc-offset, bias current etc, I plugged speakers. On first listen, I realized that all efforts was absolutely worthy for this amazing amp! I'm listening one channel with two speakers parallel and I'm forgetting each time that I'm listening actually one channel.
First big impression is DEAD SILENCE even with my 100db speakers! I never expected this level of silence. There are radio station antennas near my house those interfere with my gear easily. Circlophone barely kicked it.
Second big impression is human voice. Just impressive!
Detailed, well bodied presentation without any haze as mentioned by oddyseybmx before. I gained my expectations so far and I hope to finish second channel in short time.
Thank you for all collaboration.
Need help with OB design - cheap, cheap, cheap djn Multi-Way 38 30th May 2010 07:26 AM
Scosche SPL meter: Cheap find with potential, or cheap junk? theAnonymous1 Everything Else 5 11th October 2006 04:40 AM
Alpine cda-9831 vs. 9833 vs. 9835 cbecker33 Car Audio 3 10th December 2004 01:47 PM
Copyright ©1999-2017 diyAudio
