Old 20th September 2011, 12:23 PM   #281
Elvee is offline Elvee  Belgium
Elvee's Avatar
Originally Posted by bear View Post
it has nothing to do with the ppm, it has to do with spectra of distortion...
Could you elaborate on this?
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophoneİ ♫♪
Old 20th September 2011, 10:23 PM   #282
terranigma is offline terranigma
terranigma's Avatar
Originally Posted by odysseybmx414 View Post
I know about thermal distortion, but I am so satisfied with the sound that I am not going to change anything. Maybe I'll put it in a solid block of epoxy
I'm on the way, but I have to finish my speakers in couple days.
While preparing pcb's, did you realize that situation issued at post#274 ?
Old 21st September 2011, 08:12 AM   #283
Elvee's Avatar
Wakibaki has kindly offered a fix for this (very minor) problem:
Old 21st September 2011, 12:24 PM   #284
odysseybmx414 is offline odysseybmx414  United States
Yes, I did, and, looking at the schematic told me the quick easy fix. Otherwise, PCBs are just fine.
I cannot complain, other than the holes for the power supply input and the output transistor connections are somewhat small. Some careful enlarging of the holes and careful soldering and you can use larger diameter wire though.
What output transistors/drivers are you using terra? Just curious. I used 2SB649A's and MJW21196's. And what compensation do you plan to start with? I started right out with 270pF for C12 and build the circuit with C11 in place. I had no issues and still haven't, and it sounds better than I thought possible. I could lower C12 and/or try without C11 but I do not wish to change it, at least not for a while.
I have read of dominant 2nd order distortion sounding great and musical but lacking fine detail. I have heard of dominant 3rd having "detail" (or the feeling of?) but not sounding very musical. Then I hear the Circlophone, and I have more detail in the music than I have ever heard, and I am talking about songs I have been listening to since I was a kid. On top of that it is so musical and "sweet" than I always want to switch it on and play music, even in the most inappropriate situations.
But, good that you're not just taking my word for it and you are going to build it and find out for yourself.
What speakers are you building?
Old 21st September 2011, 06:15 PM   #285
terranigma's Avatar
I'm planning to use oldschool pcb pins on those holes. Thus, hole diameter will not an issue for me anyway. I like PCB's with old looking fashion and well applied plate grounding feature. I think plate grounding helps for amp's silence.
I want to use japan bjt's on small signal side as much as possible. I just edited pdf file for fitting 2sa devices on front side (Q1, Q3, Q4 in original schematic). That may not necessary if you know what type of transistors you are using but I could'nt help myself on this. Four matched pairs (I'm planning to build 4 channels in total if everything goes right) of 2sa970's are ready. Q12 and Q13 are will be 2sc2240.
I found gold plated Motorola 2N3020's at a local supplier and I want to use them in place of 2N3019's. I think 1.8pF Ccob 2sc2705's are perfect in place of Q5,Q6. But I like metal can devices, then those 2sc2705's may wait for chance.
As drivers, I prefer fabulous devices.. and 2sa1930's are ready.
I got plenty of NPN TO3 metal case power transistors. Those are Moto, Toshiba 2N3773 , MJ15003, 2SD110 and maybe some others. I like tweak with parts. I think I will choose output trannies after tweaking. Circlophone is a great project for these king of power transistors. These devices on my hand are generally 1-4mhz range slow but robust devices. Then my C12 will be 180pF, maybe 270pF. I think another important issue with C12 is its material. Silver mica or C0G/NP0 ceramic types must be used in my opinion.
Thank you for encouraging comments. When you look at the schematic, you capture that Designer's (Thanks for Elvee) free minded sensation and point of view easily.. No emitter resistors, no complementary devices, no bias trimmers, no fabulous boutique parts..
I'm trying build a vented box with well regarded B&C 12PE32 mid-bass' and other B&C gem, DE-250 as compression drivers. 2nd order Linkwitz-Riley crossovers just finished. Box is ready except vents and horn cutouts. This driver combination is great for acoustic and live music..And they are waiting for their Circlophone!
Old 18th October 2011, 09:29 AM   #286
powerflux is offline powerflux  Netherlands
not to offend, but i did some minor redrawing to improve readability, also based on physical location of components. keep in mind that Q7 should be close to Q2, but that would mess up the schematic.
i'm also almost finished with a single-layer PCB
Old 18th October 2011, 10:24 AM   #287
siliconray is offline siliconray  China
Wow,cool.do you have plan to make a pcb for it? Or make it commercial project? I think I can build sample of this amp for free if you have the plan .
www.siliconray.com High Quality Audio Enclosures, Amp Kits, Amplifiers, PCB Fab Services
Chat with me
Old 18th October 2011, 10:37 AM   #288
V0.1
i left out the supply caps.
happy about:
- almost fully closed ground plane
- small (7.7x5.7 cm)
- only one connection has to be made manually (red)
- components are physically close to each other when preferred, see schematic
- output-stage can be easily modified
unhappy about:
- location of ground connector
Old 18th October 2011, 01:32 PM   #289
Nice design. Have you already finished the design?
Chat with me
Old 18th October 2011, 02:57 PM   #290
ignore my v0.1 of PCB and schematic, made an error with Q7.
will update soon
edit: silly me. need more coffee! it was allready correct. still, the 0.2 PCB is better
Need help with OB design - cheap, cheap, cheap djn Multi-Way 38 30th May 2010 06:26 AM
Scosche SPL meter: Cheap find with potential, or cheap junk? theAnonymous1 Everything Else 5 11th October 2006 03:40 AM
Alpine cda-9831 vs. 9833 vs. 9835 cbecker33 Car Audio 3 10th December 2004 12:47 PM
Copyright ©1999-2017 diyAudio
