Old 29th August 2011, 01:38 PM   #201
kenpeter is offline kenpeter  United States
Originally Posted by padamiecki View Post
unbeliavle how important are inductors and 1.5 ohm resistors
I still can't get that trick to work... Would base resistors help?
Old 29th August 2011, 01:39 PM   #202
odysseybmx414 is offline odysseybmx414  United States
as above,
cannot make this...
there is no txt extension in the name, but the file has txt in the properties...
in XP I was able to make it, but under Vista or W7 impossible... or I do not know how...
I will try to make this in win commander or similar,
thanks
PS Total commander has option to change the extension, I solved the problem, sorry for offtopic
You can edit you're folder properties to view the extensions of files (.txt;.avi;.asc;etc.)
Here (first google result): How do I show file extensions in Windows XP?
Similar method to do this in other windows versions. Now you can change extensions in windows explorer very easily.
Unrelated to above:
This thread may be slightly confusing to people who are new to it. They may think that the circlophone is one of the other couple schematics posted here, or may think it is unfinished or other. Or maybe I am wrong.
Old 29th August 2011, 01:44 PM   #203
padamiecki is offline padamiecki  Poland
Here: How do I show file extensions in Windows XP?
as I wrote before I know how to do this in XP
but Vista or W7 are different.
anyway I did it in total commander and the problem is solved.
regards, Pawel
Old 29th August 2011, 01:46 PM   #204
Sorry, read to quickly I guess.
Old 29th August 2011, 03:03 PM   #205
Elvee is offline Elvee  Belgium
Elvee's Avatar
Unrelated to above:
You are probably right: to a newcomer, it must look like a ragbag of unrelated things and subjects.
It would probably be a good idea to put some order into that, perhaps by creating an index or something of the sort, I'll try to think about it.
_________________________________________________
Anyway in the mean time, here is the message to the newbies:
The schematic in #1 is still current and up to date, PCB files can be found in #53, useful construction info in #56, pdf's of the pcb are in #59, a short explanation on how the servo works is here #106, #182 is a selection guide for different power versions.
Another PCB version is currently under development and should be released soon.
You mean you loaded my asc file and it doesn't work?
If that's the case, it can only be your LTspice settings are different than mine.
Mine are all defaults: normal solver, modified trap, etc.
Note that base resistors will make things worse for stability: the circuit will reverse them, making them negative.
You bet they're important: without them, the Xquad has an infinite gain at all frequencies, including infinity.
Not the straightest path to unconditional stability.
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophoneİ ♫♪
Old 29th August 2011, 03:10 PM   #206
Distortion is indeed down, not entirely sure I trust it yet...
This thing is on the hairy edge of unstable.
Old 29th August 2011, 03:21 PM   #207
Elvee's Avatar
As you rely only on the bead's losses for damping, that's understandable.
And the beads do nothing to combat the negative resistance inherent to the circuit.
For stability, a degeneration resistor of minimum Rin/β is required. With ~470Ω, that's ~1Ω.
Old 29th August 2011, 07:17 PM   #208
oops! my bad, I picked one with only 0R7 DCR.
Old 31st August 2011, 12:11 PM   #209
Originally Posted by Elvee View Post
If you want to go even further in that direction (linearizing the LTP), another method is to use a crossquad.
The beast is difficult to tame, but it's worth the trouble:
THD @1W 1KHz can easily be pushed deep below the ppm threshold...
Hi Elvee
was it a trick to fool the simulator
or will work in practice?
regards, Pawel
Old 31st August 2011, 01:52 PM   #210
Substitute a slightly mismatched transistor across the quad,
and watch voltage offset at the output change many volts!
Granted, offset is multipled by 20, cause I neglected to add
DC blocking in the feedback loop. Probably not unmanagable.
On second though, that was idiotic of me. Any mismnatched
LTP will offset about the same, what was I thinking???
I was expecting offset to latch first one way, then the other.
But I could not get it to flip after it had taken a preference.
And the simulated distortion remained extremely low. I now
think this problem exists only in my imagination.
Need help with OB design - cheap, cheap, cheap djn Multi-Way 38 30th May 2010 07:26 AM
Scosche SPL meter: Cheap find with potential, or cheap junk? theAnonymous1 Everything Else 5 11th October 2006 04:40 AM
Alpine cda-9831 vs. 9833 vs. 9835 cbecker33 Car Audio 3 10th December 2004 01:47 PM
Copyright ©1999-2017 diyAudio
