Old 24th April 2013, 02:24 AM   #1191
de Ocampo is offline de Ocampo  Philippines
de Ocampo's Avatar
Hi! spare_parts,
I would be very glad to have a copy of *.lay file, I am also a Sprint user.
Kindly send a copy to aco.ocampo@gmail.com.
Thank You!
Old 24th April 2013, 06:40 AM   #1192
Elvee is offline Elvee  Belgium
Elvee's Avatar
Originally Posted by spare_parts View Post
I would like to upload the .LAY file for editing and printing with Sprint Layout 5, but DIY audio forum file upload says it's an "invalid file type". If anyone is interested, suggest a workaround to uploading files... If nothing else, I can try to create a PDF instead.
Try to "disguise" it by adding a .txt suffix after the .lay, and if it doesn't work, put it in a zip.
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophoneİ ♫♪
Old 24th April 2013, 02:45 PM   #1193
spare_parts is offline spare_parts  United States
Default Sprint Layout file revised
Also changed diode packages to TO-220
Old 24th April 2013, 06:06 PM   #1194
terranigma is offline terranigma
terranigma's Avatar
In my opinion those diodes must have thicker tracks at both side. Almost all current drawn by output transistors passes through these diodes. The diode at positive rail has more current swing but donated with signal level thickness track. You can do fine with only one resistors each side (1R and 0.47R), thus able to place more room for thicker tracks. Also, I would prefer to place those diodes closer to the power transistors rather than resistors.
Old 24th April 2013, 06:39 PM   #1195
Thumbs up Revised again
agreed, was looking at that also... changes added one jumper.
Old 24th April 2013, 06:45 PM   #1196
Project16 is offline Project16  France
Project16's Avatar
This is much better!
Regards!
Old 24th April 2013, 07:05 PM   #1197
terranigma's Avatar
Much better. Hope you don't forget to fix resistor values. Other things that I would consider:
* Bypass caps may be better to place to other side of fuses. Bypass caps can help for recovering nonlinear behavior of fuses if they have placed front of fuses.
* Just an idea: TO-3 metal case transistors can be fitted as an option on same layout (or alternative layout). I was working on such kind of a layout by considering Carlos' Dx super A layout's output section. You can refer to this link: http://www.diyaudio.com/forums/solid...ml#post3446208
Old 27th April 2013, 02:35 AM   #1198
de Ocampo's Avatar
Hi All!
I did my own version of the original AlexMM lay-out for the original Circlophone, lay files courtesy of spare_parts. I have eliminated the TO-39 for VAS, (this package is becoming harder to find here in my place) instead I replaced them with TO-126 type and I managed to allow a small space for a DIY heatsink on VAS. Also I made sure that I have inserted the missing 470pf on the original lay-out, replaced the smoothing capacitors with a single one and omitted the LED indicators just for simplicity of the design. I have wanted the board to become smaller in size but further modification restricts parts movement.
In case anyone will find the lay-out useful, here it is.
Thank You!
Old 3rd May 2013, 05:12 AM   #1199
de Ocampo's Avatar
Hi All, (again )
I just thought that following the basic elements is simply wonderful, this new lay-out is my preference. Experience suggests that a wider space for VAS heat sink is necessary and I have always read that an output coil is becoming necessary for an amp, this is the only addition not indicated in the basic schematic. Surprisingly the whole board is only a few inches bigger than Powerflux design.
Any comments is very much welcome.
Thank You!
Old 3rd May 2013, 10:06 AM   #1200
Project16's Avatar
Very good drawing abetir, the superfluous is removed!
Regards!
Need help with OB design - cheap, cheap, cheap djn Multi-Way 38 30th May 2010 06:26 AM
Scosche SPL meter: Cheap find with potential, or cheap junk? theAnonymous1 Everything Else 5 11th October 2006 03:40 AM
Alpine cda-9831 vs. 9833 vs. 9835 cbecker33 Car Audio 3 10th December 2004 12:47 PM
