Old 20th July 2011, 05:20 PM   #111
Elvee is offline Elvee  Belgium
Elvee's Avatar
Originally Posted by kenpeter View Post
Wasn't ever stable till I axed one stage of drivers.
But then I had to flip the whole front upsidedown.
Had no idea what I was doing, random experiment.
Stability still goes bannanas whenever it clips.
Recovery from clipping here is just plain awfull.
I would soft clip this with Zeners across R11.
One 2n3055 gets an assist from base current, the
other dumps base current into the negative rail.
So the collector currents will never be symmetrical.
Took me a while to realize I should stop obsessing
for a perfect current balance, not posssible...
Stability aspects of this topology are somewhat disconcerting: you can't use the old recipes applicable to traditional topologies.
The schemes and values I arrived at are largely based on trial and errors, most of them on the physical circuit because the sim is not quite reliable for dynamic aspects.
In addition, I've noticed on your "nothing to see" design that the current sensing via the schottky's seems to generate or at least facilitate some instabilities: I had to add an emitter degeneration resistor on the sensing transistors to achieve complete stability with a 1µs timestep.
Old 21st July 2011, 02:44 PM   #112
kenpeter is offline kenpeter  United States
Both loops stable now.
Also ditched a resistor only needed in MOSFET version.
Distortion reasonably low, considering 2N3055 at 750mA crossing.
And 165mA of that bias is always on, bypassing both Schottkys.
I am assuming "circlo" refers to how the bias servo returns full
circle, to regulate the tail CCS? My second loop compensation
loosens the harsh grip it has upon this at higher frequencies.
Things get weird if common and differential loops roll too close
same corner frequency, easily avoided. Resistors in series with
caps take gains down without rolling the phase too much, and
FT somewhere I havn't determined where (probably 2N3055?)
does final roll.
The 15R's could be parallel 33R's to enhance BOM monotony.
47pF = parallel 100pF, 1N4148 = diode strapped BC546B,
22K = series 10K's, etc... Too many different parts always
a shopping nightmare.
Old 22nd July 2011, 09:03 AM   #113
Elvee's Avatar
It looks pretty stable, even without the CM compensation network.
It remains almost perfectly behaved, even when clipping.
The schottky's as current sensors give a very nice crossing.
Have you tried it in reality?
Is it thermally manageable?
Old 22nd July 2011, 01:21 PM   #114
Schottkys are selected for overkill sized TO220 package.
But due low voltage drop, rarely dissipate more than 1W.
Current sensors should be ambient temp, NOT thermally
bonded to outputs. OK to thermally bond diode to diode,
we want crossing curves to behave as a matched pair.
Q8 should be thermally bonded to same sink as outputs,
I think then you have an ideal situation for locking into
equilibrium between operating current and temperature.
As Q8 gets hot, all other quiescent currents decrease.
If Q8 itself runs away, the amp safely shuts down...
Old 23rd July 2011, 07:08 AM   #115
Current (especially the minimum) in each 2N3055 a little more equal.
I don't have any flash of inspiration how fix the remaining imbalance.
What do do about current from base to emitter of the upper 2N3055?
Old 25th July 2011, 07:08 AM   #116
Elvee's Avatar
This imbalance isn't bugging me anymore: at the beginning of my experimentations with circlo output stages (= same sex devices but not quasi), I tried to find ways to balance the currents better, but with experience I've found there is little to be gained, quite the opposite.
Now, I happily live with it. It may be intellectually disturbing, but the real impact is very limited.
I think I'll give a try to the schottky sensors one of these days, to see what it's really worth in practice.
I am not sure coupling Q8 to the OP transistors is the best option: coupling it to the diodes might be a valid option too.
Old 25th July 2011, 08:16 AM   #117
padamiecki is offline padamiecki  Poland
Unhappy ?
Both loops stable now...
Hi Kenpeter,
in my simulator b2spice
at 19V pp output @8 ohm
I have heavy oscillations of the sine wave,
I used different shottkys (10tq045)
might this cause the oscillations?
regards, Pawel
Old 25th July 2011, 08:19 PM   #118
Schottkys should only be affecting shape of the crossover region.
Diodes doing nothing significant at 19V that could initiate oscillation.
I prefer to worry that cascode Q9 might be a positive feedback
into the Miller of Q5? Perhaps attenuate higher frequencies from
reaching the base of Q9 would help. Ferrite bead, or low pass?
I'm just guessing, not able to run a sim right now. Can you copy
and paste a model for your Schottky?
Old 26th July 2011, 07:11 AM   #119
... Can you copy
here it goes
.model 10tq045 D is = 9.81804e-08 rs = 0.00739225 n = 0.993075 tt = 0 cjo = 1.42434e-09 vj = 1.5 m = 0.479175 eg = 0.6 xti = 0.5 kf = 0 af = 1 fc = 0.5 bv = 45 ibv = 0.0001
and look of sinewave close from clipping,
upper part oscillates strong
but lower soft...
regards, Pawel
Old 26th July 2011, 03:24 PM   #120
I got to think about this...
Problem is LTP transistors dip into shut-off at high frequency, near rolloff.
Probably because in/out error seen at the comparator becomes too great.
Increasing output bias into pure Class A cures it, but not fix I am wanting.
I am not seeing any big problem your shottky .model, it changes quiescent
slightly, but easy to bring back into alignment. I have 12R where I previously
drew 33R, and 12R straight to ground on the base of the cascode transistor.
No longer driven to follow output and provide equal LTP collector voltages,
but still provides for equal LTP collector dissipation.
Mind you: Only seeing problems at 96KHz and up, 48K and down all look OK.
And only at signal levels near the boundary of true clipping. But I don't think
we should be cutting any transistors off at any frequency considered to be
"inside the envelope".
Need help with OB design - cheap, cheap, cheap djn Multi-Way 38 30th May 2010 06:26 AM
Scosche SPL meter: Cheap find with potential, or cheap junk? theAnonymous1 Everything Else 5 11th October 2006 03:40 AM
Alpine cda-9831 vs. 9833 vs. 9835 cbecker33 Car Audio 3 10th December 2004 12:47 PM
Copyright ©1999-2017 diyAudio
