Old 11th April 2013, 08:36 AM   #1181
Elvee is offline Elvee  Belgium
Elvee's Avatar
Originally Posted by EdwinR3 View Post
This version is with MOSFET's as output device.
Am I missing something? I don't see any Mos version in the zip
Some other smalle modifications were integrated to keep everything under control. The only thing that I cannot solve (don't know if it is a problem) is with squarewave exitation of higher inputvoltage and frequenty, there is still an offset.
With squarewave, there is often a problem of initial conditions leading to a large offset for a long time.
Alternatively, if the slew rates are asymetrical, it can create a small offset, wich is normally not a problem, but could be an issue with a transformer.
I have noticed that the output voltage is not equaly formed by the 2 output FET's. So I'm wondering if it should be necessary to try to match the 2 MOSFETS ?
This type of output stage uses the "virtual complements" concept, meaning symetry is as important as for a conventional amplifier.
Probably more important in the case of MOS, since the dispersion is much larger than in Bjt's
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophoneİ ♫♪
Old 11th April 2013, 09:44 AM   #1182
EdwinR3 is offline EdwinR3  Belgium
[QUOTE=Elvee;3449630]Am I missing something? I don't see any Mos version in the zip
/QUOTE]
The output transistors are IRFP4668 Power Mosfet.
I included the model in the text.
Edwin
Edwin
Old 11th April 2013, 10:42 AM   #1183
Elvee's Avatar
Here is what I find:
Old 11th April 2013, 06:54 PM   #1184
Your right (as always).
This is indeed an old test. Sorry for this.
I hope this time I will be able to complete the simple task off uploading the correct file.
Edwin
Edwin
Old 13th April 2013, 02:48 PM   #1185
Elvee's Avatar
The diode models having a suffix _C are not included in any of the zips.
There is also a call to a non-existent zetex_models library
Old 14th April 2013, 11:46 AM   #1186
The zetex lib is not used (I used to test some transistor in sim for the Q5/Q6 but it made little difference. The diode model is now included. I missed this while cleaning up my testfile.
I hope all is included now.
I should mention that here and there there are parasitic elements included in the elements to try to find out if the simulation is sensitive to these elements.
Thanks for looking.
Edwin
Old 15th April 2013, 04:01 PM   #1187
Elvee's Avatar
I have used alternative diodes to replace the missing ones, and replaced the sine source on the squarewave node by a squarewave, but I notice no particular offset problem.
If you want to highlight a particular problem, you should save a version parametrized for that situation, as it is difficult to guess which parameters exactly you have to alter to show the problem without spending hours analyzing every detail.
Old 16th April 2013, 12:11 PM   #1188
Ok, fair enough.
I included the model for the diode I missed the last time (always happens when doing something in a hurry).
To make things clear, I just wanted to know if the modifications) I made are reasonable. They were tested to try to improve the distortion figures. In some of the early variations I noticed sometimes a small oscillation at intermediate levels. They have disappeared.
I was at the time trying to replicate all the variations that were discussed.
After you mentioned that NMos works but with worse distortion, I tried some variations and came to this schema. I just noticed that my schematic is different from the one in post 62. I will point out that R9 and R12 are made unequal.
Distortion in my sim was most dependent on output transistor, bias level, but also on the type of power diodes although you mentioned somewhere along the line this is not critical. This could be caused by inadequate models. I the schematic I included two parallel diodes with the parameters I found by the manufacturer. The diodes are already paralleled in the same package. I'm not sure if this is the correct way to use them in simulation (couldn't find any info on this).
Further improvements come from replacing the servo resistor by a ccs( as you suggested), and raising the supply voltage. A further improvement I got was by doubling the drivers Q9/Q11 with a second one in parallel, but I doubt it's the trouble.
About the square wave I don't know if it is a problem, I just mentioned it because I found it strange and don't know if it is a real behavior or an anomaly of the simulator. I include some results to show how the output shifts (200Hz, 5 KHz end 20 KHz). When I checked this just now I see that even the input voltage has a small shift (red trace= input voltage x gain, green trace= output to Transformer for ESL). Real music will in reality not contain much square waves, but I suppose an amp must be capable to reproduce all signals (within reason).
If all those modifications are not causing troubles and could improve the behavior in reality, I would like to try to build it. The layout of the PCB will become more important if the improvements of distortion are to be attained in reality.
Edwin
Edwin
Old 17th April 2013, 07:10 AM   #1189
Elvee's Avatar
A number of diode models are still missing, plus a file that it tries to include, but some things can already be said: the effect of the diodes should be minimal, their presence being required mainly for energetic efficiency reasons.
If they have a significant impact on the quality, that means something is not working properly.
I think the circlophone circuit is partially paralyzed, because with the high Iq you indicate on the schematic, the upper diode must always conduct and this prevents the servo from operating normally.
Old 24th April 2013, 01:02 AM   #1190
spare_parts is offline spare_parts  United States
I have revised the layout posted by Alex to include a film input capacitor, and also changed areas that were congested, added pads for TO-XXX case transistors for the VAS, and routed new traces to the ground star to keep signal, power supply decoupling, and zobel network returns separated. I would like to upload the .LAY file for editing and printing with Sprint Layout 5, but DIY audio forum file upload says it's an "invalid file type". If anyone is interested, suggest a workaround to uploading files... If nothing else, I can try to create a PDF instead.
Need help with OB design - cheap, cheap, cheap djn Multi-Way 38 30th May 2010 06:26 AM
Scosche SPL meter: Cheap find with potential, or cheap junk? theAnonymous1 Everything Else 5 11th October 2006 03:40 AM
Alpine cda-9831 vs. 9833 vs. 9835 cbecker33 Car Audio 3 10th December 2004 12:47 PM
