Old 2nd October 2012, 04:39 PM   #1111
danielwritesbac is offline danielwritesbac  United States
danielwritesbac's Avatar
Okay, howabout this?
DIY Models & AppsClipNipperLM1875TDA7293Powerful Parallel TDA7293 kit ♦ My post has opinion.
Old 2nd October 2012, 05:06 PM   #1112
keantoken is offline keantoken  United States
keantoken's Avatar
That's pretty close. Ugly, but that's hat it takes right?
If you build it you may discover it's not needed. But it most likely is.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 2nd October 2012, 05:32 PM   #1113
terranigma is offline terranigma
terranigma's Avatar
Adding a parallel C-R circuit at NFB for avoiding cap at negative input doesn't seem to me a relevant way for abide purpose. I may be wrong but I actually prefer keep simple as much as possible NFB.
Old 2nd October 2012, 05:37 PM   #1114
keantoken's Avatar
I as sorta thinking the same thing. You trade an electrolytic for a film. It may be ugly, but maybe it's orth it?
Old 2nd October 2012, 05:53 PM   #1115
terranigma's Avatar
I also wonder why we shouldn't re-adjust compensation values of original Circlophone respecting new buffer/input implementation. Is it possible to adjust compensations for getting any advantage in terms of output device variety, flexibility, etc?
Old 2nd October 2012, 06:05 PM   #1116
keantoken's Avatar
In theory, yes. Dan has come up ith some ne compensation schemes and I have made improvements to the servo compensation. But this is all in simulation. Until someone ith a good signal generator and RF skill builds it, e ill never kno.
Old 3rd October 2012, 12:33 AM   #1117
If I put 10k parallel to the NFB cap it wouldn't have equalized the load on both transistor bases, right?
Old 3rd October 2012, 01:12 AM   #1118
keantoken's Avatar
It ould be half-equalized. You ould need to make this resistor at least 100k, and then there ould be no point.
Old 3rd October 2012, 06:33 PM   #1119
If we're stuck with the input circuit, I can simply return the NFB cap and leave the trimmer on the schematic; however, there's a lot that doesn't do.
Well, yes. That's the step out after this one. I'd like to do that without adding a lot more transistors.
Old 10th October 2012, 07:34 AM   #1120
Default New input now simplified. Needs checked.
Okay, NFB cap has returned and the protection diodes have increased to 1v, which may or may not give enough tolerance to avoid offset bounce. The static protected BAT86 are unlikely to misfire, but I have a question: Are the BAT86 durable enough for this or do I need a pair of FR/BY or similar fast silicon to get the 1v figure?
The resulting schematic is much simplified. If the input circuit passes your inspection, then I can begin work on minor compensation adjustments for phase linear up to 1.5mhz, without further increasing the transistor count. To make this sync up, I'll have to put MJ15003G or similar speed output, devices in the simulator, and then compensation adjustments, can then be quite mild, without the complexity we saw earlier. I'm trying for minimal modifications this time. But, first, an input. . . (see attachment). Is this okay?
Need help with OB design - cheap, cheap, cheap djn Multi-Way 38 30th May 2010 07:26 AM
Scosche SPL meter: Cheap find with potential, or cheap junk? theAnonymous1 Everything Else 5 11th October 2006 04:40 AM
Alpine cda-9831 vs. 9833 vs. 9835 cbecker33 Car Audio 3 10th December 2004 01:47 PM
Copyright ©1999-2017 diyAudio
