Old 1st July 2012, 08:52 PM   #1071
keantoken is offline keantoken  United States
keantoken's Avatar
Rail-rail swing is Ken's philosophy. He wants to make amps that will play during a cometary bombardment. That's my understanding anyways.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 1st July 2012, 09:17 PM   #1072
kenpeter is offline kenpeter  United States
Originally Posted by Elvee View Post
Basically, I hate anything resembling multiple supplies.
I have designed amplifiers or variable lab supplies amongst other things, but I always managed to get decent performances without this kind of prop, even high voltage supplies with full I/V control down to zero.
The plain vanilla Circlophone swings to within 1.5V of either rail without any artifice, and I think it would be a pity to depart from that philosophy.
Then we ought to drop this non-folded cascode nonsense instead.
We can't swing both rails with that added piece of junk in the way,
there is no support for adding the wart rail, to shift a cascode out
of the picture. I never saw what cascode supposed to fix anyhow...
Original circlophone satisfied all cometary collision requirements.
Some of the random "improvements" thrown at it of late, do not.
I rarely post anymore, only cause I can't come up with anything
stable that outperforms it. And not for lack of trying...
Old 2nd July 2012, 05:56 PM   #1073
Elvee is offline Elvee  Belgium
Elvee's Avatar
The Circlophone is undoubtedly perfectible and improvable, just like anything else.
And I do not not mean absolute improvement, because by adding more components, it is always possible to improve performances, but that is not what I am interested in.
What I mean is a better performance to complexity or resource ratio: a rearrangement of the existing components for instance.
The compensation scheme has in my opinion the most potential for improvement.
Kean has made a brave attempt in this direction, but not a completely convincing one so far.
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophoneİ ♫♪
Old 3rd July 2012, 03:57 AM   #1074
Oh, don't you worry, I'll bury circlophone with something revolutionary if you
don't top your own masterpiece sooner. I wouldn't put it past you to have a
few more awesome surprises under development.
I just need to get past this terrible stability barrier thats holding me back.
Almost tempted to force a known oscillation, just to claim that it was part
of the plan all along, and not something uninvited I couldn't control.
Old 3rd July 2012, 05:34 AM   #1075
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
you still have to pass one test, and that is the test of time.....like the leach amps built by thousands all over world at a time when there was only the Audio Magazine and no internet...we'll see what diy'ers will say about the Circlophone 10~20 years from now.....
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 4th July 2012, 10:15 AM   #1076
danielwritesbac is offline danielwritesbac  United States
danielwritesbac's Avatar
I think that the super important thing to remember about Circlophone is its live sound character, which, to me, is very much the reason to use it instead of a blameless/standard topology. Whatever modifications or refinements we make, it seems good or even important to retain the "sounds live" benefit. I do not know the cause of the unique characteristics.
What I've got prioritized is:
1. Attempt lower current in the feedback shunt resistor, such as using 1K instead of 470R to see if it is possible to push the efficiency peak higher than the audio band rather than landing at 8khz sometimes, and seemingly better to prevent/block a treble problem instead of solving it by parts swapping, but parts swapping is the current solution at this time.
2. The BC560C buffer arrangement that the simulator claims just makes stuff run a little bit better despite some minor variances in compensation or not. Well, I haven't soldered that up yet because I've been working on line level stuff and catching up on the roundtoit list. BC560C's are not rare so there's no shame in requiring them, and it is looking like a good idea.
3. Get a higher powered circlophone to run as well as the low powered example in post 1 (because higher power can push a wider variety of speakers). Currently a transistor turns off on the higher powered versions and there is sometimes but not always a frequency response or treble harmonic errata (I don't know which) on the higher power versions. Perhaps that problem will disappear after exploring 1 or 2 above?
The more I learn, the more questions I find.
DIY Models & AppsClipNipperLM1875TDA7293Powerful Parallel TDA7293 kit ♦ My post has opinion.
Old 4th July 2012, 02:34 PM   #1077
EdwinR3 is offline EdwinR3  Belgium
Hello,
I tried to simulate several variations of the circlophone driving ESL speaker with a 1:150 step-up transformer. It shows the idle power of the upper output transistor (MJL21194) is 2.8 Watt, but the lower (negative) side one dissipates 308 W. If i change the load to a resistor of 8R, the iddle power are 5.9 and 6.4 W respectively. A load resistor of 3R gives almost the same results.
Can someone point me in the right direction to solve this ?
With circloMOS i'm getting I can get much reduced iddle power dissipation of the O/P stage, but the distortion is far inferior.
Edwin
(i could post the LTspice file if someone is interested).
Edwin
Old 4th July 2012, 02:39 PM   #1078
Elvee's Avatar
That would be the first thing to do....
Old 4th July 2012, 06:42 PM   #1079
Ok Elvee, here it is.
For your information, the amp is supposed to be driven by a miniDSP board mith Zout of 560R, and Vrms max = 0.9V. For some configurations the headroom seems to be rather limited. The ESL will be crossed over to a subwoofer at 120 Hz and the DSP will need to boast +/- 8dB at 160 Hz.
The step-up should be able to give a Vpk of 3.5KV.
Thanks for looking in to this.
Edwin
Edwin
Old 4th July 2012, 08:38 PM   #1080
Elvee's Avatar
Some transistor models are not included, so I couldn't run the simulation, but anyway the likely cause of the problems is the lack of a DC blocking capacitor in the output, and/or a low/absent winding resistance for the transformer.
I wasn't able to track the actual series resistance used by the simulation: I saw it equaled Rip, which then equaled Ris, but then I lost the track.
Even if there is a finite series resistance, it is probably not a good idea to drive the transformer directly: normally, this type of transformer is ungapped and has a high permeability, and the winding resistance is low.
All this means that even a negligible output offset voltage will be sufficient to saturate the core.
It will also cause a high dissipation in one of the OP transistors, because the amplifier will try to impose this OS voltage to a low resistance.
Try inserting a large cap in the output, this should fix the problem.
BTW, making R23 ~=0 will probably cause problems. Even if they don't appear in the sim, the reality will be less forgiving.
Need help with OB design - cheap, cheap, cheap djn Multi-Way 38 30th May 2010 07:26 AM
Scosche SPL meter: Cheap find with potential, or cheap junk? theAnonymous1 Everything Else 5 11th October 2006 04:40 AM
Alpine cda-9831 vs. 9833 vs. 9835 cbecker33 Car Audio 3 10th December 2004 01:47 PM
