Old 26th June 2012, 12:09 AM   #1051
keantoken is offline keantoken  United States
keantoken's Avatar
The BC560C VAS needs no more than say 1V Vce, you could probably get away with less.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 27th June 2012, 05:44 AM   #1052
kenpeter is offline kenpeter  United States
VAS, which VAS? As-if it were nailed down to one location.
The one that pulls up against constant current for half the cycle
Or the entirely other one that pulls down against constant current
in the opposing half cycle?
If the common mode loop is disabled, you have no less than five
transistors that could be VAS Q 5,6,7,8,16...
Old 27th June 2012, 06:08 AM   #1053
keantoken's Avatar
I described it as the "BC560C" VAS... And I was referring to the cascode voltage.
Old 27th June 2012, 04:09 PM   #1054
I havn't seen a schematic of this thread with BC560, at least not lately.
Also havn't seen where I can pinpoint a solitary VAS. Cascode voltage
could mean anything outside the context of a specific schematic and
reference designator that you have neglected to reference.
It certainly makes no sense in the default context of the most recently
posted schematic #1049. Please post your current schematic or link to
past required to make sense of your statement.
Old 27th June 2012, 04:40 PM   #1055
danielwritesbac is offline danielwritesbac  United States
danielwritesbac's Avatar
Originally Posted by kenpeter View Post
The output cannot swing very low with that cascode in the way. Have you considered the existing negative rail for cascode base? You would have to provide an extra negative rail for circlophony. But it needn't be anything elaborate since the common mode is
strongly controlled by quadrature anyway, a 5v wart might do.
I don't know what it means without seeing the difference between two options. Could you post a schematic, so I could see?
That is doable. See attachment.
DIY Models & AppsClipNipperLM1875TDA7293Powerful Parallel TDA7293 kit ♦ My post has opinion.
Old 28th June 2012, 07:17 AM   #1056
I love the way you use BC560 as both an NPN and PNP.
Old 28th June 2012, 07:39 PM   #1057
That was a fluke. Hopefully someone would use BC550 when it comes time for the NPN. Point taken--BC560 vas did look a bit odd. So, anyway. . .
The output cannot swing very low with that cascode in the way. Have you considered the existing negative rail for cascode base? You would have to provide an extra negative rail for circlophony. But it needn't be anything elaborate since the common mode is strongly controlled by quadrature anyway, a 5v wart might do.
How is your demonstration schematic coming along to explain that extra negative rail to fix the cascode? I just can't quite imagine it from the words, but a schematic or even a sketch would be great.
Old 28th June 2012, 10:11 PM   #1058
keantoken's Avatar
Actually, using PNP for Q3 and Q4 is an interesting idea. This would reverse frontend and servo phase, making it an involving change.
Old 30th June 2012, 08:57 AM   #1059
Elvee is offline Elvee  Belgium
Elvee's Avatar
I tested the idea. It seems to work, but with a THD figure approximately doubled, which is consistent with the degeneration of 4 junction resistances in the VAS, compared to two in the regular Circlophone.
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophoneİ ♫♪
Old 30th June 2012, 09:26 AM   #1060
keantoken's Avatar
But, now there is indefinite drive available from the VAS. An important difference WRT harmonics. Furthermore, the increase in distortion could be compensated by doubling R4 and R12 in your schematic.
It's interesting anyways.
Need help with OB design - cheap, cheap, cheap djn Multi-Way 38 30th May 2010 07:26 AM
Scosche SPL meter: Cheap find with potential, or cheap junk? theAnonymous1 Everything Else 5 11th October 2006 04:40 AM
Alpine cda-9831 vs. 9833 vs. 9835 cbecker33 Car Audio 3 10th December 2004 01:47 PM
Copyright ©1999-2017 diyAudio
