Old 21st June 2012, 08:13 PM   #1041
Elvee is offline Elvee  Belgium
Elvee's Avatar
Originally Posted by danielwritesbac View Post
I got these values worked out from adding a resistor series to C2 to represent a lossy imperfect cap. The sim freaked out with instability as usual, whenever that resistor is present.
When you apply non-default minor parameters to a component, you should show it explicitly when you share a graphic-only attachment on the forum, Otherwise, it is completely impossible to guess (and even then, you have to look into the component in question, that's not obvious)
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophoneİ ♫♪
Old 21st June 2012, 11:02 PM   #1042
danielwritesbac is offline danielwritesbac  United States
danielwritesbac's Avatar
Previously indicated at post 1039, there was indeed a temporary torture test, and after achieving the higher quality of hardened centerpoint values, all parts were re-checked and shown at default prior to posting.
As shown, it does not contain any non-default minor parameters. But it will resist them.
DIY Models & AppsClipNipperLM1875TDA7293Powerful Parallel TDA7293 kit ♦ My post has opinion.
Old 22nd June 2012, 12:44 PM   #1043
Elvee's Avatar
OK, it should be fine then.
I do not get similar results, but I use the original Circlophone parts, that's maybe what causes the divergence.
The only thing that remains to do is to validate the circuit with a physical prototype, and check the improvements do indeed materialize.
Old 23rd June 2012, 02:51 PM   #1044
krokkenoster is offline krokkenoster  South Africa
Exclamation circlophone
This is exactly what I was thinking! Did you guys build this extremely invoved circuit or was it just theory? I discovered that the more simpler a thing the better it perform at the end. Ok I was looking for a circuit that could give me a reasonable output (20 Watts or so) for home use. How long will those little output transistors last if they get driven this hard to their maximum? Fatter transistors are not all that more expensive and WILL last a lot longer.
Old 23rd June 2012, 11:51 PM   #1045
Here's a link to the build thread.
http://www.diyaudio.com/forums/solid...-friendly.html
Refer to this schematic for your 20 watts (actually 27 watts):
http://www.diyaudio.com/forums/attac...e-original.gif
If this looks overly complex, try an LM1875 for good practice.
P.S.
To quickly rough estimate, with 57% of datasheet dissipation watts for AC (Music or PWM) output, I just pulled up the MJE3055 datasheet, saw 75 watts from OnSemi, used the calculator with a crude *0.57 and got ~43 watts into 8 ohms. SO, the smallest of the 3055's generously exceeds your 20w requirement by approximately 215%. A problem was where???
It is true that the MJL21194 in the simulations with 4 ohm speakers does not meet this criteria (it is "almost"); however, it is also true that some small rail pulldown (a minor volt or two) will occur at this point, thus meeting the safety estimate requirements in real life unless your capacitor bank is gigantically too big so that rail stiffness erroneously lasts longer than SOAR test timeframe, but that sort of error is rare due to the expense of causing it, so really, the MJL21194 should work fine if your rails are 35+35vdc.
The power output niche obliterated by the hi-fi LM1875 projects is why I didn't show voltage lower than 35+35vdc on the sims, and the output device selections is why I didn't show voltage higher than 35+35vdc on the sims. Of course we could do higher voltage if it was known that 8 ohm speakers are used. We're actually only using a fraction of the MJL21194's capacity.
And, the strong MJ15003 is available! These are not puny.
Old 24th June 2012, 12:45 AM   #1046
Originally Posted by keantoken View Post
The compensations being applied here are becoming, shall I say, multiplicitous... Though if that ends up with a better result, I think it's pretty cool.
Well, to me it looks like none of it is an overdo (let's check that again) and all of it is better than the usual strong miller comp or similar heavy-handedness. What looks familiar is that most good hi-fi amplifiers usually have a dozen small and transparent corrections instead of a big fell swoop. Although it is important that all of the corrections are small/transparent to audio, it seems even more important that all would be different so that they can't add up to any peak in the sonic signature. What do you think?
Old 24th June 2012, 12:55 AM   #1047
keantoken is offline keantoken  United States
keantoken's Avatar
Well in this case, the servo was out of balance. One side would be stable but the other would not. So one side had to be either sped up or slowed down.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 24th June 2012, 01:05 AM   #1048
kenpeter is offline kenpeter  United States
That was my impression, that one half presented a different Bode than the other?
I kinda deviated towards a circlopony in complimentary symmetry, as-if that were
some kinda magic bullet to make both Bode the same. Now even with perfect open
phase, both differential halfs are equally unstable in .tran . I got rid of my input pair
Miller by neutralization, and there probably lies the greater part of my folly.
Neutralizaton on the top side only works when the tail isn't messing with the class
Aness of it all from the bottom side...
Old 25th June 2012, 09:05 AM   #1049
BC556B, 2N3019, 2N5551, BD140-10, MJ15003, no other changes from the last sim, phase linear, the square is squared and 0.002608%THD
Old 25th June 2012, 11:01 PM   #1050
The output cannot swing very low with that cascode in the way.
Have you considered the existing negative rail for cascode base?
You would have to provide an extra negative rail for circlophony.
But it needn't be anything elaborate since the common mode is
strongly controlled by quadrature anyway, a 5v wart might do.
Need help with OB design - cheap, cheap, cheap djn Multi-Way 38 30th May 2010 06:26 AM
Scosche SPL meter: Cheap find with potential, or cheap junk? theAnonymous1 Everything Else 5 11th October 2006 03:40 AM
Alpine cda-9831 vs. 9833 vs. 9835 cbecker33 Car Audio 3 10th December 2004 12:47 PM
