Old 6th June 2012, 11:24 PM   #1001
danielwritesbac is offline danielwritesbac  United States
danielwritesbac's Avatar
The drivers in post 998 are Philips BD140, but many drivers could be used for those results, since it isn't touchy about drivers.
However, it is very touchy about VAS components, and thus if 2SC5171 is exchanged for a substitute then the function would be less pleasant than expected. The problem is the capacitor parallel with the feedback resistor. Not only is tuning that in harmony with the vas compensation giving the excellent performance but it is also an Achilles heel. Some other and more tolerant way needs to be found or else there would be a schematic per each different vas device and per each different voltage. For example a variety of 5 transformers and 5 transistors requires 25 different schematics. . . because the vas compensation has tight tolerances and will neither successfully nor automatically adapt to differences. Ideas?
DIY Models & AppsClipNipperLM1875TDA7293Powerful Parallel TDA7293 kit ♦ My post has opinion.
Old 7th June 2012, 12:06 AM   #1002
keantoken is offline keantoken  United States
keantoken's Avatar
Removing RC compensation from the LTP has probably made the circuit less tolerant to VAS changes. An LTP RC comp with say at least 500pF of capacitance may be sufficient to swamp out VAS differences. I'm not sure, maybe more is needed.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 7th June 2012, 12:09 PM   #1003
kenpeter is offline kenpeter  United States
VAS??? How can we speak of VAS in normal terms?
Modulated into Class B from beginning to end, you
have two very different VAS in a game of ping-pong.
The transistor that is shut off or held at low constant
current is not amplifying anything by comparison to
the other half which is active.
I see you have recently added Q16 to make both
halves of the cycle more similar. When did this
new part first appear, and why was it not worthy
of previous mention? It cuts severely into your
negative swing's headroom, so its not pure gravy.
Why bother at all with V6 + D8? If Q16 exists,
these should be mated with the same.
Old 7th June 2012, 12:51 PM   #1004
keantoken's Avatar
D8 is to keep the simulator from determining an operating point where V6 is pushing current the wrong way through the driver. It is just for the simulator.
I like your idea to cascode Q4 with the top of D8 as a reference.
AFAIK the VAS is in class A, except when overdriven or when being severely messed with by the servo loop. Furthermore, the servo loop itself ensures that the VAS, just like the output stage, has that non-switching characteristic. Furthermore, the VAS is certainly balanced, or currents of the outputs wouldn't be balanced or controlled so well, which they are.
In simulation a single 500pF cap across the bases of the VAS works well to iron out differences, ensuring a baseline of slowness. This modification should make me and Dan's variant more tolerant of different VAS devices.
Elvee, I know you've probably been there done that, but I value your input. As for instability... I haven't built it so I don't know what I'm missing... But I've been there with my current amp, so I think I have an idea. My experience is that there is probably a way to get the amp to work like in simulation, assuming the models aren't terrible and the real life devices aren't counterfeit.
Old 7th June 2012, 01:17 PM   #1005
Its ping-pong alright. One output transistor under control
of the differential feedback, The other under control of the
common mode feedback. Then roles reverse... And this
goes all the way back up the chain to the modulated tail.
Things only get complicated if the common feedback is
slower than the differential. If it were not quick enough
to hold the roles as separate. And during the crossing.
When we slug a VAS that affects both loops, are we then
shooting ourselves in the foot by enforcing a mixer in the
critical part of the Bodes where both rolloffs will occur?
I am not saying mixing makes unstable. I am saying the
mix makes analysis a nightmare. Becoming manageable
only if you break the problem into chunks that don't defy
traditional Bode analysis. As Bode assumes there will be
only one global loop, and it will be open. But ours must
properly handle the open differential mode with common
mode loop is closed, and therefore...
Old 7th June 2012, 01:37 PM   #1006
keantoken's Avatar
The servo is pretty slow. At frequencies that matter for compensation, the VAS is operating pretty much without any common-mode augmentation.
The 500p cap actually does not slow it down that much. Remember that low values of miller capacitance matter because they are multiplied by the voltage gain of the stage. This does not happen to emitter capacitance.
Old 7th June 2012, 01:56 PM   #1007
It might also be OK if the common mode is significantly
slower than differential. As this becomes class A at high
frequencies, and we know how to stabilize for that. But I
worry that way of compensation would invite meltdown
if an oscillation were to establish in spite of our efforts...
Faster, slower, either might be OK. But not the same.
Probably not anyway, I can't prove what I can't math.
And I cannot math this mixed Bode. I have tried.
If we approach the problem by slugging something
that affects both loops, we risk making both rolloffs
occur near the same corner. Full tentacled madness....
You want the common mode to dumb down to classA
somewhere above audio. and then much further above,
roll the differential? I suppose that is not so confusing...
What happens with a clipped audio signal that has a
high frequency component in the class A zone?
Old 7th June 2012, 02:48 PM   #1008
keantoken's Avatar
I'm pretty sure the VAS will still saturate before the LTP does. Remember that Elvee's versions have a lot more across the VAS bases, 1.5nF as I remember. Albeit with some series resistance, but the critical difference is that in that version the LTP would have saturated before the VAS. So I don't think this version would have any problems that Elvee's didn't have, in fact it may be better.
Old 7th June 2012, 03:15 PM   #1009
Elvee is offline Elvee  Belgium
Elvee's Avatar
I found that the static and low frequency aspects of the Circlophone are very accurately modelled by the sim.
For the dynamic aspects, it is a different story and there are discrepancies.
Some are positive, like the slew rates, power bandwidth and transient cleanliness as shown in the oscillograms better than the sim, some negative, essentially stability, worse than the sim.
The stability in a Bode sim is a necessary condition for the physical stability, but it is not sufficient by itself.
My hypothesis is that the two loops interact, creating a sort of "modal oscillation".
This cannot be caught by a simple Bode analysis, where you look essentially at the result of one stimulus on one loop at a time.
The transient analysis should be more accurate in this respect, and it sometimes is: making a simulation with very small time steps, like 1ns can help uncover some issues. But some discrepancies remain.
Maybe the models, maybe the physical layout, or some other unknown effect.
When oscillations occur, they are generally rather high in frequency, several MHz, and low in amplitude, less than 1Vpp thus pretty harmless and non-destructive.
So, it is perfectly feasible and safe to experiment and test various compensation schemes, practically without risk (not on a real speaker though).
Amongst other things, I found the lead resistor in series with compensation capacitors was practically unavoidable.
But maybe I was stuck on the wrong track and missed something. That kind of thing can happen when you are involved too deeply for too long in something, which is why I welcome the look of outsiders.
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophoneİ ♫♪
Old 7th June 2012, 08:52 PM   #1010
Elvee's Avatar
I made a quick test on two Circlophone builds I had handy: one is a completely unaltered version, with TIP3055 as OP, the other is based on BD249C.
I simply shorted R23:
On the plain vanilla C, it resulted in downright oscillations on the positive half cycles, on the BD249 one, nothing was visible.
This means that with somewhat better output devices, the margin is wider, but it doesn't mean it is sufficient for practical use.
At the time, I made my homework and made stress tests under many marginal conditions, with many semi's, etc, and came to the conclusion that the values published were near optimum. Or at least a local optimum. If a completely different compensation strategy was adopted, things might be different, but if the original scheme is retained, series resistors are probably necessary.
I know that it doesn't quite square with sim results, but in the end it is the physical circuit that has to be made to work, not the sim.
Need help with OB design - cheap, cheap, cheap djn Multi-Way 38 30th May 2010 07:26 AM
Scosche SPL meter: Cheap find with potential, or cheap junk? theAnonymous1 Everything Else 5 11th October 2006 04:40 AM
Alpine cda-9831 vs. 9833 vs. 9835 cbecker33 Car Audio 3 10th December 2004 01:47 PM
Copyright ©1999-2017 diyAudio
