Avondale NCC200 module pics
Old 13th August 2003, 08:49 AM   #1
IanHarvey is offline IanHarvey  United Kingdom
Default Avondale NCC200 module pics
For your general enlightenment, here's some pics of my latest project, based around Avondale Audio's NCC200 modules - see http://www.users.zetnet.co.uk/avondale/
Cheers
IH
Old 13th August 2003, 08:55 AM   #2
Here's the innards -
PSU is a 35-0-35, 625VA transformer and 2 x 22000uF caps. Rectifier was built on another Avondale PCB using (IIRC) BYW51 fast-recovery diodes.
The internal power wiring is mostly Silver Anniversary bi-wire (as it's basically very chunky ribbon cable), and as you can see I've tried to avoid supply & return currents from forming any loops of substantial area.
Old 13th August 2003, 08:58 AM   #3
Here's a closeup of the module itself. I bought the bare PCBs and all the other bits come from Farnell. I made a few transistor type substitutions - BC546s for BC182s, because the supply voltage was right on the Vceo limit, and MJ21194 output transistors.
Old 13th August 2003, 10:00 AM   #4
li_gangyi is offline li_gangyi  Singapore
li_gangyi's Avatar
hmmm...interesting...I have a question though...is the flat pack mj21194 better or the TO3 version?? I assume it's the TO3 one...
Kids in the back seat cause accidents...Accidents in the back seat cause kids...
Old 13th August 2003, 10:37 AM   #5
Measured performance is excellent:
Power output is about 90W into 8ohms, 180W into 4.
Frequency response is about as flat as I can measure, (<0.1dB, 20Hz-20Khz).
Sine-wave distortion seems to be entirely 2nd-harmonic, at about -80dB, at pretty much all frequencies/power output/load
combinations. The trace below was at about 10W out into 8Ohms, at 5Khz.
No measurable hum / PSU breakthrough at the output, and no detectable instability with long leads, capacitors, loudspeakers, etc.
Old 13th August 2003, 10:40 AM   #6
Given a choice, I'd go for the flat pack one, as it's easier to mount (by basically clamping it to the heatsink with a big bar of aly), and there's no 'case' connection via screws & insulators & whatnot, but the PCB is for the TO3 one.
Cheers
IH
Old 13th August 2003, 11:14 AM   #7
li_gangyi's Avatar
perhaps you can saw off a little part of the PCB...thin out the tracks and drill a few holes for flat-packs to be installed...or use a few pins sticking out for mounting...a little messy looking though...but izzin't TO3 suppossed to conduct heat faster?? Or is the flat pack better in this area...??
Old 13th August 2003, 12:06 PM   #8
According to the datasheets, both have the same junction-to-case thermal resistance (0.7 deg C/W), but ... the flat-pack is rated 200W at a 150 C junction temperature, whereas the TO3 is 250W and 200C.
So, roughly speaking, they are the same thermally, but you can run further into the danger zone with the metal TO3 case.
Cheers
IH
Old 13th August 2003, 12:53 PM   #9
li_gangyi's Avatar
Ok I get the main idea...but dun manufacturer's use the same die for the different packages...if so why the diff?? Maybe I shouldn't be asking here...but I'll ask anyway...
Old 13th August 2003, 01:23 PM   #10
Da5id4Vz is offline Da5id4Vz  United States
Da5id4Vz's Avatar
Send a message via AIM to Da5id4Vz
Very nice.
XLR and Speakeron connectors, is this for your home Hi-Fi?
Avondale NCC200 module picsHide this!Advertise here!
Quad 405-1 Avondale AndrewGM Solid State 0 21st October 2008 12:26 AM
avondale audio modded arcam alpha 5 - AAA5 - anyone tried it? anubisgrau Digital Source 3 16th September 2007 06:37 AM
GB150 (SKA), GB300, NCC200 and chip-amps Dr.H Solid State 2 1st September 2006 06:06 AM
TVC and Avondale mcds Solid State 0 20th October 2004 04:09 PM
Avondale Arcam Alpha 5 t. Digital Source 0 26th May 2003 01:04 AM
