Leach Amp: help troubleshooting - diyAudio
Old 13th January 2002, 06:38 PM   #1
swede is offline swede  Switzerland
swede's Avatar
Default Leach Amp: help troubleshooting
Hi there!
Well, I finally got one channel up and running on my Leach Amp, and I did all my testing at the workbench. So I decided to take her out for a ride and hooked the darn thing on to my Yamaha DSP A2, that would do as a pre-amp.
It started out really well and it sounded great!
BUT
In my joy, having her up and running, I got a bit trigger happy and powercycled the amp, and this is where my troubles start. (I cycled it really quick. The amp was off for only one second or so)
All by a sudden, there was this really squealing noise from the loudspeaker and after a second, the fuse blew. When I replaced the fuse and turned on the amp again, C22 blew up (and there was this smell, you know)...
http://users.ece.gatech.edu/~mleach/...aphics/ckt.pdf
I tried and replaced the transistor Q17, but I blew another set of fuses.
Where should I start looking for errors/broken stuff?
How do I see that a transistor is broken?
Which transistors/diodes/caps are most likely to be broken?
As I mentioned before, the amp worked and sounded really good until I powercycled.
Hmmmm... I'll try and change q12, q13, q14 and q15.
Any ideas?
Have a good one,
//magnus
Old 13th January 2002, 06:59 PM   #2
subwo1 is offline subwo1  United States
subwo1's Avatar
Bummer. The way to start is to check all of your semiconductor devices in the last two stages. It is best to remove each from the circuit and at least check the diode junctions and also collector to emitter for transistors. Put your meter on the diode test range. Each diode junction should give a reading of at least about .4V for a power transistor and around .7V for most other devices containing diodes. Then reverse the probes on each diode junction and you should get an infinite reading. For collector to emitter checks, the reading should be open circuit in both directions. Basically, the main thing is that no reading between any two pins on a semiconductor should read a short, or close to 0.
Old 14th January 2002, 02:48 AM   #3
bawang is offline bawang  Malaysia
Exclamation Counterfeit parts?
Sounds like what happened to my Leach Amp when I used (unknowingly) counterfeit MJ15003/4 output devices! Check the output and driver (Mj15030/31) stages.
After I've replaced my output stage to real MJ15003/4 devices, I can powercycle as many times as I like without problems...... except the dimming of the lights when the transformer powers up and charges the input caps......
Old 14th January 2002, 08:55 AM   #4
swede's Avatar
Thanks a lot,
It was one 15003 and one 15004 that had blown away. 15030 and 15031 was OK. I have wait a couple of days for new transistors, so I hope it isn't any more problems with it.
bawang: Counterfeit? How did that happen?
//magnus
Old 14th January 2002, 09:28 AM   #5
Hi Magnus. Yes, counterfeit (ie fake!) devices. Check out the thread on counterfeit transistors. My counterfeit MJ15003/4 devices have printing that can be easily rubbed off (with a rough cloth), thicker base etc. See attached file that I've obtained from Dick Smith Elec., Australia.
Old 14th January 2002, 09:31 AM   #6
Oops...... too large....here's the image, Magnus...
File Type: jpg id fake motorola mj15003 and mj15004.jpg (89.5 KB, 1019 views)
Old 14th January 2002, 12:50 PM   #7
ppl is offline ppl  United States
ppl's Avatar
I would like to sugest Better Transistors to the Ones mentioned. The MJ-15003 and MJ-15004 TO-3 Power types witth Type MJ-2193 and MJ-2194 TO-3 Types if available in your area. Also the MJE-15030 and MJE-15031 with MJE-15032 and MJE-15033. All these transistors have Better Performance and Higher Ft's than the Old types showen.
Old 14th January 2002, 02:06 PM   #8
Geoff is offline Geoff  United Kingdom
ppl
I think you meant that to read MJ21193 and MJ21194.
Geoff
Old 14th January 2002, 04:06 PM   #9
swede's Avatar
But then again, why would the power transistors blow when I powercycled the amp?
//magnus
Old 14th January 2002, 10:03 PM   #10
Location: Auburn, WA (somewhere between Seattle and Tacoma)
Send a message via ICQ to Damon Hill
The circuit was apparently oscillating; I hope you have an
oscilloscope. It may do fine on a resistive load but misbehave
on a reactive speaker load. I had that happen when I didn't
install the Zobel network and hooked it up to my speaker system,
which is four ohms and uses Kimber 4TC cable. It wasn't
audible, but the output stage ran very warm, the oscillation was
very high frequency, and was bias setting dependent. I even
missed it the first time I put a scope on it because the frequency
was so high. The recommended Zobel fixed it instantly.
Recheck for wiring errors and that your grounding scheme
conforms with the recommended practice. Given that a bypass
cap on the circuit board blew, you'll have to replace that one
and be sure it's the recommended value. If you can find them,
try using low-impedance caps.
My Leach Amp Clone (LEACH 150) panson_hk Solid State 32 22nd May 2014 11:25 AM
High Current Leach/leach super amp bowdown Solid State 41 2nd March 2011 02:15 PM
troubleshooting zv9 neil_kaye Pass Labs 6 13th April 2007 09:57 PM
Leach Superamp vs Leach 4.5 Samuel Jayaraj Solid State 4 26th October 2002 09:20 AM
Leach amp vs super Leach amp supernet Solid State 0 21st February 2002 10:16 PM
Copyright 1999-2017 diyAudio
