Does solder quality have an adverse effect on sound?
Old 12th August 2003, 10:30 PM   #1
Corn-Picker is offline Corn-Picker
Question Does solder quality have an adverse effect on sound?
I want to build an AKSA 55 or 100 Watt amplifier. I would consider myself a novice solderer. I've put a few of the small robotics kits together, and the AKSA PCBs look a lot larger than those
Will a less than perfect solder sound worse than a professionally soldered joint? Or is all that matters whether or not electrical contact is made?
Would a straight 60/40 lead solder be good for audio work? I don't want to start a whole debate on the sound of silver as I inadvertently did on another board; I'm just wondering if the 60/40 mix is acceptable for audio work.
Also I've heard that electronics periodically need to be re-soldered. Why is this? I'm assuming this is because of the oxidation of the lead tin alloy not because of physical degredation, but I'm not certain.
Thanks in advance for any help
Old 12th August 2003, 10:33 PM   #2
On Hiatus
SY's Avatar
Solder joint quality is indeed critical.
Standard 60/40 works fine and is just about the easist type with which to achieve a good solder joint.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 12th August 2003, 11:03 PM   #3
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Hardly anyone can teach you how to solder...this comes with many hours of practice.
So, why not do just that before you embark on a more serious project?
A decent soldering iron ususally helps big time in getting it right too...
Don't worry about that for the time being...it's a once every other ten years thing that only us anally retentive purists consider doing anyways and usually accompanies some upgrades of components left and right in the process...
Cheers and enjoy,
Frank
Old 12th August 2003, 11:10 PM   #4
john curl is offline john curl  United States
john curl's Avatar
Get some good SN62 or SN63 solder. Get a NAME BRAND, not Radio Shack. One lb. will last you forever, and you will always get good solder joints. Don't cheap out here, as you will just make your life (in soldering) that much more difficult if you do.
Old 12th August 2003, 11:14 PM   #5
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Does solder quality have an adverse effect on sound? Send a message via AIM to Peter Daniel
You might check this: http://www.diyaudio.com/forums/showt...s+on+soldering
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 13th August 2003, 10:34 AM   #6
Circlotron is offline Circlotron  Australia
Circlotron's Avatar
63/37 type solder is even nicer because it has the lowest melting temperature ~600 deg F. Even more important, because it is eutectic, when it is cooling it has no plastic state - it goes straight from liquid to solid so there much less chance of making a bad joint if it is disturbed while setting. It looks nicer too - makes a much more shiny joint than 60/40 stuff.
What do I use? 60/40 also I have been playing with some lead-free stuff but the flux in it is a bit weak and it needs a tip of about 800 deg F to melt easily. Makes ok but bad-looking joints.
Best-ever T/S parameter spreadsheet.
http://www.diyaudio.com/forums/multi...tml#post353269
Old 13th August 2003, 10:58 AM   #7
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
Default Re: Does solder quality have an adverse effect on sound?
This is only necessary if you have problems. Electronic gear with especiially temperature variations can experience stress in the solder joints. This can happen faster if the part when it was new had oxidized pins (old parts on the shelf which are soldered in).
The general apply: If it ain't broken, don't fix it.
Every time you heat up a solder joint you degrade especially the pcb but also the part itself.
Most problems has thick pins and/or heavy parts.
Also when you solder, don't forget to heat up sufficiently. A newbie error is fears the harm the part by heat. Only certain film caps are sensitive, like polystyrene.
BTW: What is hiatus? (sinbin halo)
/Per-Anders (my first name) or P-A as my friends call me
PA03 LM4780 amplifier group buy, SIGN UP HERE for the group buy 0 boards left. 118 paid.
Old 13th August 2003, 04:58 PM   #8
mrfeedback is offline mrfeedback  Australia
mrfeedback's Avatar
I find that Multicore Savbit (60Lead/38Tin/2Copper) tins very well, is long term reliable, and as has been discussed previously on this forum is the best sounding of the lead based alloys.
To make good solder joints, good solder (see above), a good solder sponge and a good vari-temp solder station are required.
For practice, find an old TV pcb and practice re-soldering until you get it right.
If the components are clinced down onto the pcb, any movement is not an issue, and in my experience eutectic solder sounds wrong.
Multicore make 96S solder (96Tin/4Silver) and this sounds the best that I have heard, but is difficult to get right and is expensive.
Big tip - clean the solder with tissue and solvent to remove any oxides on the surface of the solder wire before soldering operations - NASA techniques as I was taught in the early 80's.
Eric.
I believe not to believe in any fixed belief system.
Old 14th August 2003, 03:02 AM   #9
mbroker is offline mbroker  United States
mbroker's Avatar
Lots of good advice in the thread Peter linked to. The best way to get good at soldering is to practice - a lot.
I've been using this 96% tin/4% silver solder exclusively for over 3 years now. It started when I needed some lead-free solder for a Tesla Coil capacitor, and RS was the only place around. After a couple thousand solder joints one weekend (not PCB!), I had gotten the hang of it. This is the stuff I use, despite its cost, for almost everything: RS cat# 64-026. It's also available in .031" diameter. I explicitly recall Fred D recommending it in some thread, though I no longer recall if it was sarcastic or not (it was in one of those long, drawn out sound of "X" arguments).
Good luck,
Mark
Old 14th August 2003, 03:43 AM   #10
Diode is offline Diode  United States
To answer your question.... YES, it does make a difference in sound. That's a pureist point of view though and we all know that the pureists live on Pluto.
A lot of very good information but I suggest whatever solder you get you need to get good heat transfer between parts and pads. You will see the solder flow into all knids of places that you wouldn't think it would but it follows heat. I use a good liquid flux and clean it with MEK or Acetone. 99% Isopropol alcohol works OK too. If the joint isn't shiney, drop a small drop of liquid flux and reheat but just enough that the "ball" of solder reheats and that's all. Then clean again. 60/40 solder will work fine for us "Earthlings" LOLOL
Good luck
Chris
The best audio is clean audio!
Does solder quality have an adverse effect on sound?Hide this!Advertise here!
Quality Control differences = variations in sound quality? KT Class D 3 4th June 2014 12:02 AM
My new ideas to have quality sound effect. space2000 Solid State 39 12th July 2010 06:35 PM
Wanted: A few feet of high quality *thin* solder... Peteruk Swap Meet 6 11th June 2007 12:05 PM
Strong solder, how does it sound? classd4sure The Lounge 33 23rd September 2006 09:47 AM
the sound of solder diy student Solid State 18 29th October 2001 03:51 AM
Copyright ©1999-2017 diyAudio
