Does solder quality have an adverse effect on sound?
Old 16th August 2003, 03:07 AM   #21
Diode is offline Diode  United States
Majority of diyAudio members seems to be from the 2%-world. Who know...?
Hey, A lot of people on the forum know about good design, as I stated. What percentage of them truly fall into this category? Not much. The people here know design for which I have great respect for. With sound or great sound, opinions are as many as the people in this forum......
Best of luck with your soldering to all..... Sometimes it's a pain for even a seasoned veteran!
Chris
The best audio is clean audio!
Old 16th August 2003, 04:21 AM   #22
Wardsweb is offline Wardsweb  United States
Practice practice practice...Soldering is a learned art. You will find it's better to take your time. Let the iron do the work. Rule 1, the solder is your heat bridge, let it work for you. You will learn this quick when a dry iron won't solder squat. Clean your iron ( I prefer a good wire mesh pad versus a wet sponge that will lower your tip temperature just when you're ready to solder) "Tin" your iron tip and use a good quality solder. I use Kester "44" rosin core solder (63/37). It helps to also tin (presolder) you parts; wire, leads... and remember " the bigger the blob, the better the job" is NOT TRUE. I remember going through NASA certification and you want to talk about "anal". This is to much, that's not enought, that's just right, and even with a microscope. Wait till you get to hot air then the fun really starts. Bottom line, take your time and it will save you headaches down the road. Now have fun, after all this is a hobby.
Old 17th August 2003, 02:45 AM   #23
Good post.... I will agree and disagree with you at the same time. Mostly, "the bigger the blob...." Try repairing pro audio, especially guitar amps and keyboards. The jacks and filter caps need big blobs!!! Most of the POTs as well!!!!
So, ya done any BGA rework? Now that's fun. I like working under a microscope too but those jobs dried up a couple years ago.
OH WELL!
Chris
Old 17th August 2003, 02:53 AM   #24
mrfeedback is offline mrfeedback  Australia
mrfeedback's Avatar
Default Less Is More.....
Granted large components like sockets etc require more solder for the mechanical properties, but Frank has commented in the past that minimal solder is sonically better than excessive solder.
Eric.
I believe not to believe in any fixed belief system.
Old 17th August 2003, 03:25 AM   #25
sam9 is offline sam9  United States
sam9's Avatar
The best solder to use is the one you find easiest to work with because that's the one that will give the best joints. A while back I was concerned about some delicate ICs that I tried a Kester specialty solder #58/245 that has a very low melt point. I've gotten in the habbit of using it for general use because it is so quick for both soldering and de-soldering that it compensates for fading near vision and shaky hands. (Us old geezers have to put up with a lot!)
Old 17th August 2003, 04:21 AM   #26
mrfeedback's Avatar
Soldering is a process of alloying the solder into the surfaces of the parts being co-joined.
This process takes time and is critical to long term reliability.
Imo, quick lower temp soldering doesn't do the job quite right.
Eric.
Old 17th August 2003, 02:43 PM   #27
Corn-Picker is offline Corn-Picker
Here's the NASA-STD-8739.3 standard for soldering, as of 1997 anyway.
http://nepp.nasa.gov/DocUploads/06AA...STD-8739.3.pdf
I'll just keep practicing on my small robots I think the AKSA will be easier than the robot kits in a lot of ways, those pads on the AKSA PCB are huge compared to those little pads of the kits I've been working on.
Old 17th August 2003, 02:57 PM   #28
mrfeedback's Avatar
Try assembling it with 96S and I am sure you will be very pleased.
Eric.
Old 17th August 2003, 03:34 PM   #29
A great way to get better without hurting any projects is to use a solder practice kit. You can do a search for "solder practice kit" and find lots online. The one below I did as part of a certification class. It is from Omni.
Old 20th August 2003, 01:42 AM   #30
john curl is offline john curl  United States
john curl's Avatar
IF you are new to soldering, just get SN62 or SN63 from a quality manufacturer. Don't waste your time, at this point, with anything else. Trust me, I built my first Heathkit in 1959. Some kits that I built, even then, still work, but they look pretty bad, inside. SN62-63 will keep you from cold joints and both are low temperature solders. Flux quality(inside the solder) is important! Don't cheap out with RS. Get a name brand.
Does solder quality have an adverse effect on sound?Hide this!Advertise here!
Quality Control differences = variations in sound quality? KT Class D 3 4th June 2014 12:02 AM
My new ideas to have quality sound effect. space2000 Solid State 39 12th July 2010 06:35 PM
Wanted: A few feet of high quality *thin* solder... Peteruk Swap Meet 6 11th June 2007 12:05 PM
Strong solder, how does it sound? classd4sure The Lounge 33 23rd September 2006 09:47 AM
the sound of solder diy student Solid State 18 29th October 2001 03:51 AM
Copyright ©1999-2017 diyAudio
