Old 15th May 2011, 09:57 PM   #1
Default P3A vs LM4702 AMP's
I Am debating on the p3A amp or a lm4702 amp.
i built a LM4702 amp with KSA1220A/KSC2690A drivers and 2SC5200/1943 outputs and i think it sounds really good.
some people say it is not that great, it sounds alot better than a TDA7294 amp i have (sharp and tinny).
What do you think about the sound quality of the P3A do you think it sounds better than the LM4702
do you know any other amps that tested/sound better than the P3A/LM4702
Old 16th May 2011, 05:17 AM   #2
jon2xflash's Avatar
i think dx amps may sound better...........
Old 16th May 2011, 09:25 AM   #3
sakis is online now sakis  Greece
sakis's Avatar
obviously there is no serious point on doing that ...then again alot has to do on the way you have builted the P3a ...
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 16th May 2011, 09:59 AM   #4
ostripper's Avatar
KSA1220A/KSC2690A = not the best for drivers but it will most likely kick the pants off the p3a.
OS
Mongrel website , always current and updated :
http://67.248.209.21/D%3A/WEBSITE/
Old 16th May 2011, 10:41 AM   #5
Why exactly are they not the best drivers they have a high hfe
Im only driving one pair of output transistors.
A dx amp is better than the p3a and lm4702?
Old 16th May 2011, 11:18 AM   #6
wahab is online now wahab  Algeria
It will be better because it has more power and this will
inevitably have an influence on the perception of the sound..
Other than that, there are very few amps by there that can
be qualified as high definition/high performances, and most
are not worth the effort since it would be better to use
an used 80s japanese amp and refresh it..
Old 16th May 2011, 11:21 AM   #7
ostripper's Avatar
Drivers can be MJE15030/31 -32/33-34/35 or 2sc4793/2sa1837 , better for more load on OP devices. MJE's are good to about 3 pair OP devices (heavy duty).
"Better" is subjective. What is better ? You must build more of them , decide for yourself. Symasym , all of DR. Jagodics (bora's) designs , my AX ... all very good. DX is most simple , no way to "mess up".
OS
Old 16th May 2011, 10:46 PM   #8
Im thinking about building the DX amp
is there any really noticeable sound quality difference between the standard dx and the the DX HRII.
Old 17th May 2011, 01:48 AM   #9
saurus is offline saurus  United States
As far as ESP's amps go, I have built the P3A and the P101 using Rod's pcbs, and I think the P101 sounds much better than the P3A.
Old 17th May 2011, 06:11 AM   #10
sakis's Avatar
small details for each and every amp mentioned above might cause al ot of diference choise and or combination of semis is one of them ...choise of other parts or choise of bias level
standard versions on standard pcb is something i have no expirience with so i have no opinion ....
as abouts OS's phrase most likely kick the pants off the p3a. i would troully like to see an amp that performs easily 100K square wave with the top corners just rounding up at 100 KHZ to be kicked out by something of the same range and simplicity to built ...
kind regards sakis
My New amp's jleaman Solid State 21 21st December 2006 06:03 PM
Just some picture's of my amp's lykkedk Everything Else 0 11th March 2006 12:16 PM
Amp's with 2SK413/2SJ118 TroelsM Solid State 13 26th August 2005 03:52 PM
amp's inner wiring rnzr Solid State 2 15th April 2005 01:51 PM
2 AMP's????? Ryancowe Car Audio 5 26th May 2004 04:39 PM
Page generated in 0.12494 seconds (63.51% PHP - 36.49% MySQL) with 11 queries
