Is this monoblock common?
Old 12th August 2003, 01:55 PM   #11
PMA is offline PMA  Europe
PMA's Avatar
Tim, this may depend on local safety laws/rules. It is possible to have an instrument in metal case with the case not connected to protective earth (in Europe). This depends on transformer's class of isolation, i.e. on the tests and certifications that transformer must fulfill. Why P-A speaks about line filter? That's because this has a middle point connected to the metal case. As filter has capacitors between phase and neutral, phase and chassis and neutral and chassis, the chassis must be connected to PE for safety reason.
But as I stated, this is a little controversial topic, as countries have different mains distribution networks with different kinds of voltage/touch protection and different safety rules.
Old 12th August 2003, 03:17 PM   #12
trwh is offline trwh  United Kingdom
trwh's Avatar
Thanks for your post, PMA - I see what peranders means now.
I was aware that it is in theory possible to have a safe mains powered product with an unearthed metal chassis - my CD player is an example of this. However, it was mentioned to me that the requirements for doing this legally are very stringent, and it is easier and safer for the DIYer to just earth the chassis. Any ground loops can be defeated by the use of a ground loop breaker circuit, as described here:
http://sound.westhost.com/earthing.htm
I hope that helps,
Tim.
Is this monoblock common?Hide this!Advertise here!
Common Source versus Common Drain output stages alaskanaudio Solid State 36 1st June 2014 02:35 AM
Yet another monoblock Sch3mat1c Solid State 4 22nd August 2009 12:00 AM
The best DIY monoblock? christianlie Solid State 10 17th December 2006 01:56 PM
500 watt monoblock RogerG Solid State 45 12th April 2005 01:05 PM
a 71A monoblock Joel Tubes / Valves 30 30th December 2002 09:19 PM
