HELP- with heatsink-amp connection
Old 12th August 2003, 02:26 AM   #1
mikee12345 is offline mikee12345  New Zealand
mikee12345's Avatar
Unhappy HELP- with heatsink-amp connection
heres a pic of my eti amp,i need to fix it to this heatsink
it has 5 holes already in the bracket..only 2line up.
how many screws should i use? as many as possible
if i drill lots more holes,wont that reduce the amount of surface area contacting the heatsink..so how many?
should i use the existing 2,and drill 2 more,that makes it even.
or should i drill 4 more,making 6 screws in total
btw it doesnt need such a large heatsink,but later i might bridge it with another..
also im going to add some limiting transistors on output to stop it from drawing too much current.
<50watt into 8ohm amp class a/b>
also,should i smear heatsinking compound onto the bracket-heatsink face? it doesnt say to in the manual but it couldnt hurt if i have some left over.
Old 12th August 2003, 02:33 AM   #2
JOE DIRTŪ is offline JOE DIRTŪ  Canada
JOE DIRTŪ's Avatar
LOL....Mike your picture is so small that its hard to judge.....give us some dimensions....like Length of the heat sink
A good nominal figure would be every 3 inches or so and compound would be good also
a few holes wont decrease the effieciency any
Cheers!!The DIRTŪ
Old 12th August 2003, 02:41 AM   #3
mikee12345's Avatar
Default dont u love tiny webcams
sorry :-P
there is already 5holes at about 27mm apart,but only the 2 end ones match up with heatsink..
about13cm long bracket and 30cm long heatsink
35mm long fins 10mm apart
should i put 2 screws each side near the transistors themselves,leaving none in the middle? or put 2 there too lol/.
Old 12th August 2003, 02:44 AM   #4
mikee12345's Avatar
those 3 holes are where the drivers go thats all.
they dont need much heat dissipation do they?
HELP- with heatsink-amp connectionHide this!Advertise here!
psu connection bigpanda Parts 3 11th May 2008 03:17 PM
PC to DAC connection? zhai Digital Source 12 20th October 2006 06:12 PM
AES/EBU Connection fmak Digital Source 2 20th September 2003 12:29 AM
pot connection rocktboy Chip Amps 2 25th June 2003 09:31 PM
