Hi All
Got this SONY XO-3 Receiver a few days ago. It is very unque in that it has AMP, Tape Deck and 3 Band tuner (FM MW LW). I have not seen or read about it before. But when I connected it up - the amp sounds fantastic from my SONY CDP and SONY turntable, the Tape Deck works fine too, but the Tuner - FM is barely audible with very good FM antenna - that's with volume full up, MW & LW has no output at all (MW & LW has built in ferrite antenna at the back - this should work fine, but no sound). Tonight, I open it up just to see if there is any short or disconnected wires - but nothing I can find. Everything seems together. I have connected long wire into the MW antenna terminal as well - not a sausage. Internal components all seem clean and intact (not messed with, it seems). Where next should I look into? Thanks in advance. |
#2 |
Time to check the power supply voltages to the tuner section. See if you can locate a service manual. http://www.stereomanuals.com
#3 | |
Thanks echowars.
Weird thing is that I can hear some stations on FM, but very quiet - must put the volume up to about 12 oclock position, but nothing on MW and LW. I will try to find the service manual, but this model seems a bit obscure one - which might be difficult to find it. cheers. Quote:
| Looking for SONY ST-80F tuner manual | djoffe | Solid State | 0 | 24th July 2010 09:12 PM |
| Someone has offered me a Sony ST 5130 tuner, should I take it ?? | Shoog | Analogue Source | 6 | 30th June 2010 09:10 PM |
| Sony ST-S310 tuner trouble | hiwiho | Analogue Source | 5 | 5th November 2006 10:49 AM |
| Bad Tuner on Sony REC-800 | snaps98 | Car Audio | 0 | 5th October 2005 08:58 PM |
| Problem with Sony tuner memory | Lourens | Analogue Source | 8 | 18th July 2005 06:45 PM |
| Page generated in 0.09010 seconds (61.66% PHP - 38.34% MySQL) with 10 queries |
