Old 11th May 2011, 09:02 AM   #1
endeo is offline endeo  Croatia
Default Sony TA-F35 help
Hello I am new to the forum so i asked myself if you could help me...I have a sony TA-f35 integrated amplifier.....my uncle gave it to me to repair it and that it is a test of me as a electrician(I`m i school still...) so an older engineer told me to replace the output transistors and a couple of other components so the problem is the amp is powered up and the fuses are not blown but there is no sound so if anybody could tell me what and where to look...thank you(sorry if I put it in the wrong forum)
ImageShack Album - 3 images
here are the photos of the stripped amplifier..
Old 11th May 2011, 11:06 AM   #2
jaycee is offline jaycee  United Kingdom
Check the output protection relay - does it click on power on? If not, that is a problem, either the protection circuit is faulty, or it's in protect mode. Its also worth checking the relay's contacts as they will be tarnished over the years.
For a unit this old you will also want to replace every electrolytic capacitor.
Old 11th May 2011, 07:32 PM   #3
Thanks....but about an hour ago I soldered the transistors again and it works but the sound is not so lound what could be the problem?
Old 12th May 2011, 01:48 PM   #4
ilimzn is offline ilimzn  Croatia
You are looking at hundred or so parts... anything could be the problem. There is no sense in trying to fix it by randomly poking around. You need a schematic (look at HiFi Engine | Download Free User/ Service Manuals, Amplifier, Receiver, CD, Tape, Tuner, Video) and at least a multimeter to find out what is wrong. Only then can you get it right. A random exchange of parts ending in a working amplifier is like lottery - luck, not knowledge.
Old 12th May 2011, 02:36 PM   #5
Could be anything from dirty switches and pots to bad capacitors used for signal coupling. It could even still be tarnished relay contacts. If you really want to repair an amp this old, you need a schematic and to be prepared to give it a good overhaul - cleaning, replacing aged parts, etc...
Old 13th May 2011, 08:18 AM   #6
Who said I poked around randomly?I am not a fool to go check 300 components randomly one by one and I already measured the voltages with the schematics and now it works all I had to do was to clean it up a lot.....
Sony TA-F60 CrazzyAbtTubes Solid State 6 18th October 2009 10:53 PM
sony ta f 870es domus71 Solid State 4 12th May 2007 10:45 PM
Sony TA-N1 and TA-NR1, how do they sound? lumanauw Solid State 0 28th November 2006 01:51 AM
Sony TA-NR10 mikeks Solid State 0 28th May 2006 01:40 PM
FS: Sony "Esprit" TA-E901 and TA-N901 pre and power amp MJR Swap Meet 1 6th December 2003 07:55 PM
Page generated in 0.09967 seconds (70.37% PHP - 29.63% MySQL) with 10 queries
