I am looking for the simplest design, wattage output anywhere between 150-250 Watts RMS.
I would like to study it and its components so I can understand the basics. I have successfully built a tube amp, working on my second one - and have a very decent knowledge on tube theory. However, I am considering an SS build for my powered home subwoofer. My final goal is to eventually add different filters to the circuit, including a clip filter (protection), and an effective EQ system (maybe parametric) to adjust the frequencies between 10Hz and about 120Hz. Other filters would include an adjustable rumble filter (subsonic filter), a low pass filter adjustable from ~80-200Hz. I would like to learn each part in sections / blocks so that I can design my own model for my own applications. But for starters, I would like to understand the most basic AB mono power amp, including the essentials such as simple preamp and power supply. Thank you! |
#2 |
Its not the best circuit but it is about as simple as it gets: http://i.imgur.com/PNIwH.png
I've built this and its working and sounding nicely. Note that you can use almost any driver and power transistors, like BD139/140 or MJE340/350 for drivers and anything from 2N3055 to big expensive bipolars for the outputs. |
| Simple TDA2050 mono amp for PC | ToMiC | Chip Amps | 19 | 14th March 2011 11:04 PM |
| 150 watt mono SS amplifier | Original Burnedfingers | Swap Meet | 7 | 2nd November 2007 09:44 PM |
| Simple 12v mono power amp for bass driver | dhole | Car Audio | 4 | 13th November 2006 02:27 AM |
| I need a simple ss reverb for a ss guitar amp. | yeto | Instruments and Amps | 8 | 18th January 2006 06:54 AM |
| Page generated in 0.06618 seconds (71.41% PHP - 28.59% MySQL) with 10 queries |
