Old 11th August 2003, 06:43 PM   #1
Default who is making these transistors (originally NEC audio output)?
Just received these parts. Original manufacturer is NEC. The 2SC 2987 part bears the NEC mark. The S does not seem to be the gain group, as this can be R, Q or P.
The 2SA1227 part is puzzling me. I have never seen this logo of three tick marks in a circle. Again, there is no gain group.
Eric
Old 11th August 2003, 07:36 PM   #2
JOE DIRT®'s Avatar
Capslock the 2sa2987 is a npn 140v 12amp 120watt 60mhz transistor and the 2sc1227 is a pnp complimentary mate with the exact same specs........the latter is a probably a generic clone from a another manufacturer
Cheers!!The DIRT®
Old 11th August 2003, 08:37 PM   #3
Duo is offline Duo  Canada
Duo's Avatar
Send a message via ICQ to Duo
Joe Dirt: You do mean 2sc2987 and 2sa1227 do you? Instead of having the c and a mixed?
-- Duo, W1ngs, VA7MON, and lesser known handles. --
-- http://www.w1ngselectronics.com -- My Work and Projects --
Old 12th August 2003, 08:47 AM   #4
Yes, I now the specs, I even have the NEC data sheet in Japanese.
My question was who manufactured the A1227. My experience is that those clones are usually not full second sources. Just look at the data sheets for the Sanken 2SC2837 and the Mosspec clone by the same part number. Gain linearity, fT and Cob are so much worse that the part should not be allowed to go by the same number. I have some WEC parts for which I found no data sheets which are, judging from simple measurements, also much worse than the orginals.
Old 12th August 2003, 10:04 AM   #5
Netlist is offline Netlist  Belgium
diyAudio Moderator Emeritus
Netlist's Avatar
Capslock, have you tried this:
http://www.angelfire.com/electronic2/rch/logoa.html
Greetings
/Hugo
Old 12th August 2003, 11:45 AM   #6
Hi Hugo,
thanks for the link. Unfortunately, not all letters work (dead sub-links). I will keep trying.
Greetings,
Eric
Old 12th August 2003, 11:50 AM   #7
JOE DIRT®'s Avatar
my apologies I did mix up the the letters Duo
DIRT®
Old 12th August 2003, 02:54 PM   #8
Netlist's Avatar
Indeed, perform a search on "IC logo", or "IC id" or similar things.
There is more to find, however, I gave up after 15'; Ones get dizzy by looking at all those logo's
You could try this too: http://tess2.uspto.gov/bin/gate.exe?...ate=e7qht4.1.1
but then you're busy for months..
/Hugo
Old 15th July 2005, 06:19 AM   #9
thanh is offline thanh  Viet Nam
thanh's Avatar
Send a message via Yahoo to thanh
I want to view 2SA1227's datasheet . I searched it by google but it is to difficult to look for it . Who can help me ?
Justice for Victims of Agent Orange
http://www.petitiononline.com/AOVN/Thank all of you!
Question about audio output transistors and power out ElectronicsTech Solid State 24 3rd May 2009 02:08 AM
Audio Research output transistors muizel Solid State 2 15th March 2007 08:56 AM
Wanted: TC2+ 15" drivers originally sold through OAudio boogs Swap Meet 0 26th January 2007 02:44 PM
HELP NEEDED: Making coaxial digital output to SONY CDP cartman Digital Source 3 31st July 2005 05:58 PM
Another way of making the output section with class A predriver JensRasmussen Solid State 10 5th August 2004 09:04 PM
Copyright ©1999-2013 diyAudio
