Old 9th May 2011, 05:12 AM   #1
jetblac is offline jetblac  United States
Default Adcom GFA-555 Blew main fuse after turning on in bridged mode
Hello.
Just picked up a Adcom GFA-555, all was fine. The next day I bridged it, (properly) when I turned it on the main fuse blew. Okay ... so I put it back in stereo mode, and it blew the main again. Okay ... next time I removed all of the rail fuses, and it still blew the main. Does this sound familiar to anybody? I can try to get my money back or haggle for a discount since it is broke, but as you can tell, I have no idea what I am getting into.
Back story: I have another 555 that was bridged to the other speaker and that one is still fine.
Chime in, if you can. Thanks
Old 9th May 2011, 06:29 AM   #2
jackand08's Avatar
If it still blew the main fuse even after you removed the rail fuses, then (assuming that the rail fuses remove any kind of connection between the transformer and the amplifiers) it looks like you may have a faulty mains transformer. How this could've been caused by a faulty bridge mode, I don't know as transformers usually hold up pretty well against faults on the secondary side.
Why it blew the first time may be difficult to say, but it could've blown the second time due to the wrong fuse type being used. Did you replace it with a slow blow/time lag fuse?
Also, when wiring it in bridge mode, did you wire the speaker between the two positive outputs of the amplifier (neither speaker lead grounded)?
Jack
"Near enough is good enough, so good enough is right" My Site
Old 9th May 2011, 06:35 AM   #3
Mooly's Avatar
Top off, and measure the output transistors for starters. See if any are short circuit.
Those and the bridge rectifier, I can't see it being anything else tbh.
A simulation free zone. Design it, build it, test it.
Old 9th May 2011, 08:56 AM   #4
sakis is offline sakis  Greece
sakis's Avatar
common failure is the bridge rectifier.... for this amp there is no soft start circuit and the singlest trigger in the power could easilly short the rectifier ...
kind regards
sakis
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 9th May 2011, 02:55 PM   #5
Slow blow? there was an AGC in there.
and yes, it was wired correctly.
Adcom gfa 555 help 406vette Solid State 34 15th October 2011 03:34 PM
Adcom GFA-555 eelekim Pass Labs 2 14th May 2009 03:42 PM
Adcom GFA-555 MKII turns on, blows fuse, speaker hums down £§«û‰ Solid State 8 21st June 2008 10:52 PM
Adcom GFA-555 claiborne Solid State 8 27th September 2007 10:20 AM
FS:Adcom GFA 555 and GFA 5300 trusound Swap Meet 0 13th December 2005 05:06 PM
Page generated in 0.08884 seconds (70.78% PHP - 29.22% MySQL) with 10 queries
