in a nut shell, im trying to build an amp. im using a NE5532 to take my line voltage to amplify it to 20Vp. from there i want to use common emitter using 2N2222A/2N2907 to get my rail voltages of +/-30V. From that, it will go to my main driver transistors (tip31/32) in a push-pull configuration.
I did the calculation and what not, but on my scope things aren't working as they should. Normally I think id be able to fix this on my own but im hitting a brick wall and i know when i need to humble myself to people who may know much more. Below is are Multisim screen shots that can help. Ill try to answer any questions you need asap. Sadly, i cannot provide an entire schematic at this time since i dont have a scanner fr my notebook but i hope this helps: |
#2 | |
V= 30(5000) / (5000 + 200)= 28.85Vdc at the base of the 2N2222. That means an emitter current of: Ie= (28.85 - 0.6) / 1000= 28.25mA The drop across the 15K collector resistor wants to be: 15(28.25)= 423.7V ![]() You only have 30Vdc, therefore you've driven the 2N2222 way way way into saturation. What, exactly, are you trying to accomplish here? If it's a simple gain stage with Av= 15, you sure don't need such huge resistors to get that much gain from a 2N2222 (or any other BJT). |
#3 | |
#4 |
You can click 'Reverse' in your oscilloscope to get white background
lineup |
| Emitter bypass caps in a CE stage | Novice62234 | Analog Line Level | 31 | 1st March 2011 03:21 AM |
| Need help understanding current sourced common emitter/source amplifiers | GregH2 | Solid State | 9 | 26th February 2011 06:14 AM |
| Calculation of input impedance (Common emitter amplifier) | jazko | Solid State | 22 | 22nd January 2011 10:35 AM |
| Basic Common Emitter Amp Help | Obe1 | Analog Line Level | 99 | 21st February 2010 05:08 PM |
| Class D amplifier with common components | ratmayor | Class D | 5 | 7th October 2008 07:45 AM |
| Page generated in 0.08126 seconds (73.76% PHP - 26.24% MySQL) with 11 queries |
