what is standard how many uf and volts when someone says standard high voltage caps
#2 |
Depends on the supply voltage and the currents drawn.
High voltage are those with considerably high rating. Higher than the supply voltage.
lineup |
#3 |
so building a BA-1 600 va converter with four main caps what would be considered standard?
#4 |
What is BA-1?
And how high voltage? 600VA sounds very much.
lineup |
#5 |
its burning amplifier 1
| Why use High Voltage rated caps in Xover? | plmedeiros | Multi-Way | 8 | 9th October 2010 10:24 AM |
| High quality, high voltage (~250V) reservoir caps for PSU | thadman | Power Supplies | 5 | 10th May 2010 09:18 PM |
| High Voltage Electrolytic Caps | Bengali | Parts | 4 | 19th October 2007 07:45 AM |
| Source for high voltage electro caps | pollypocket | Tubes / Valves | 5 | 21st March 2007 08:45 PM |
| High Voltage Power Supply Caps | Bryan | Tubes / Valves | 14 | 4th September 2005 07:31 AM |
| Page generated in 0.07282 seconds (68.15% PHP - 31.85% MySQL) with 10 queries |
