Hi all.
I've seen different configurations of quasi outputs. I would like to know which is correct, and each has particular characteristics. 1- Naim amplifier 2- Quasi amplifier Thanks |
#2 |
Both are correct.
However I found with my quasi amp i needed a small capacitor from the lower driver transistor collector to the base to stop oscillation on the output.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
#3 |
Hi nigelwright7557.
Thanks for you reply. Ok. I have seen this cap in different amplifiers (Arcam A60). My question is, if the transistor down resistor must be in the collector (Naim) or emitter (Quasi)? The different configuration quasi, have some effect on the sound? |
#4 |
Hi all.
My question is, if the transistor down resistor must be in the collector (Naim) or emitter (Quasi)? The different configuration quasi, have some effect on the sound? Some advantage? |
#5 |
Hi, the two baxandall diode arrangements above seem identical to me, rgds, Sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow |
#6 |
The one on the right, with parallel transistors seems to be using the emitter resistors to help balance the current between these parallel transistors. These resistors will also have an effect on the local feedback of the "pair" (maybe for the better but one would have to analyze that).
The resistors to the load I think are more likely for bias current setting and its temperature stability. Hope this helps -Antonio |
#7 |
HI.
Thank you very much for your responses. Now, I have another question, why is not the Baxandall diode in quasi mosfet amplifiers? Regards Guillermo |
#8 | |
The short answer is bias voltage is far higher and Fets need far higher drive voltages than transistors at high currents, essentially adding the diode does little in this case, it doesn't affect the symmetry of the output stage much. rgds, sreten.
#9 | |
Add the diode increases the gain of the lower driver. This is fine but I found the increase in gain could also cause instabilty and oscillation on the output. I found I had to add a small capacitor across b-c on the lower driver transistor.
#10 |
Nigel,
You can always put a 22nF across the diode to smooth the gain transition..... seems to stabilise Quasis very well. Hugh |
| Quasi complimentary output stage? | metalsculptor | Tubes / Valves | 9 | 5th November 2010 10:59 AM |
| output pnp quasi amp need? | tadiam1 | Solid State | 0 | 1st June 2010 06:57 PM |
| quasi-complementary output | Vlad | Pass Labs | 4 | 13th April 2010 12:07 PM |
| Balanced quasi-floating output | xocoatl | Parts | 2 | 30th December 2004 01:18 PM |
| Page generated in 0.10989 seconds (76.74% PHP - 23.26% MySQL) with 11 queries |
