My amp's power transistors (right channel) were burned by accident. Faulty transistors are replaced with the new ones (matched pair), but I found they are cooler than left channel. I am sure both channel has same bias current, and I am wondering what could be the cause of this problem? If it is the hFE, which channel is higher? Thanks.
#2 |
If it was bad thermal transfer, then the heat sink will be cooler, but the transistors are hotter. maybe the original side is running hotter because it doesnt have fresh pads?
#3 |
I think it's not the thermal transfer. Everything is the same, except the transistors. If I touch the transistors, they are different in temperature.
#4 |
Banned
Less losses at high frequencies?
#5 |
The only explanation would be that the transistors are not
mounted such as the thermal dissipation is isotropic in respect of their positionning.. That often occur when one side of the heatspreader has better thermal contact with the case than the other side, the transistors being mounted symetricaly on the heatspreader... |
#6 | |
And don't ignore what nightanole is saying . . . dried up (old) heat sink compound on the left channel would cause the transistors to run hot . . . consider re-mounting them (like the new ones) with new grease, pads, or whatever was used on the right channel. |
#7 |
Yes, both bias current are monitored by two DMMs. The power transistors are 2SC3519/2SA1386. They are, of course, not from the same batch. Do you think different hFE would cause this?
#8 |
No, heat comes from current x voltage. You have measured the current, and presumably the voltage is the same, so the lower temperature must mean they are being cooled more efficiently. hFE is not an issue.
#9 |
Banned
are all devices manufactured by SanKen? Could it be oscillation? |
#10 |
they are all Sanken transistors. On my scope, there is no sign of oscillation. I am going to replace the left channel to see what happens. This time, all transistors are from the same source with identical batch number. |
| Can I build up these Darlington transistor if I use two BJT transistor ? | gaborbela | Parts | 9 | 15th July 2010 06:30 PM |
| Can bias transistor mount on top(body) of output transistor?? | Leolabs | Solid State | 23 | 16th February 2008 12:35 AM |
| WTB Krell KSA Mk2- working or non working | Jozua | Swap Meet | 0 | 20th March 2006 11:14 AM |
| Transistor and Temperature | lumanauw | Solid State | 10 | 12th September 2004 09:44 PM |
| transistor amps not working for me... | trespasser_guy | Solid State | 15 | 23rd May 2003 12:49 PM |
| Page generated in 0.11718 seconds (78.59% PHP - 21.41% MySQL) with 10 queries |
