A few questions on this amp design...
Old 4th May 2011, 07:11 PM   #1
Boscoe is offline Boscoe  United Kingdom
Default A few questions on this amp design...
Just wondered if some people could help me out. I want to do this sort of amp design as it isn't too complex but I only have 2SA1492 and 2SC3856 and I don't want to buy any others so would they be compatible? If not could someone suggest something?
Secondly can someone suggest a cheap and easy program to design the PCB for this?
Thanks.
Audio projects and more: gswdh.co.uk
Old 4th May 2011, 07:42 PM   #2
xeclipse is offline xeclipse  Kenya
Location: Where the world's best tea come from:Kericho Kenya
Its hard to get help without these: schematic? power? speaker impedance?
if there are no sparks,it probably doesn't work!
Old 4th May 2011, 07:59 PM   #3
Haha sorry forgot to put the link in!
HERE is the link to the design!
Speakers are 8ohm I would like about 100W
Also like to know if I can increase the amount of output devices?
Old 4th May 2011, 08:07 PM   #4
lineup is offline lineup  Sweden
lineup's Avatar
yes. that's a good design.
And there are several options of power transistors.
I am sure your transistors will work, too.
And there are instructions how to put it together.
If you like you can order nice PCB boards from ESP Rod Elliott
lineup
Old 4th May 2011, 08:54 PM   #5
Boofers is offline Boofers  Canada
PCB123 and ExpressPCB are free PCB design programs. Once you design your board you can use these programs to order your boards, and they will manufacture them and ship them to you. Or you can do what I do and just use the program and make your own boards.
Old 4th May 2011, 09:15 PM   #6
Okay thanks but I want to know for definite whether these transistors will work though.
And yes I would rather order the PCBs from Rod Elliot but I want two pairs of output devices without bodges!
Old 5th May 2011, 07:04 AM   #7
lineup's Avatar
I searched: 2SC3856 replacement
with google.
MJL4281/MJL1302 should be good replaments.
So, I say you can be sure that you can use those in Rod Elliott project
lineup
Old 5th May 2011, 09:14 AM   #8
As long as you don't exceed the devices' SOA,you are good to go.
Old 5th May 2011, 09:21 AM   #9
chlorofille is offline chlorofille  Malaysia
chlorofille's Avatar
I used MJL21193/21194 for my P3A and they worked fine. Right now I am rebuilding it with 2SC5200/2SA1943 which have a very low output capacitance(200pF).
With 2 pairs of transistors and +/- 42V, the amp can deliver 100W into 8Ohms. Do not use 4 Ohm speakers with this voltage.
For higher power, look at Rod's P101 mosfet amplifier.
A few questions on this amp design...Hide this!Advertise here!
Wall wart alternative/AC power supply design & housing questions ew Power Supplies 9 31st October 2010 10:21 PM
Metronome style design for multiple drivers, a number of design questions mountainhick Multi-Way 5 28th January 2010 03:31 AM
AB2 guitar amp design questions Craig405 Instruments and Amps 12 8th January 2008 06:01 PM
Guitar amp PT design questions voivodata Instruments and Amps 5 21st July 2007 07:26 AM
Starting First Amp - Questions on Mono Block Design jawbreak Chip Amps 3 12th December 2004 01:00 AM
