What amp would be best for my four polk audio m10 bookshelf speakers (the speakers are put in parallel 4 ohms per channel)
amp 1 : LME49810/LM4702 with MJE15034 Driver 2SC5200 Output or amp 2 : 60-80W Power Amplifier with MJE15034 Driver 2SC5200 Output Question about amp 2, for Q9 can i use a BD139 mounted on the output transistors as the vbe multiplier. are there anything i can do to amp 2 to make it sound more "audiophile like" |
#2 |
Hi, specification wise the LME combo is superior on paper but when
in terms of real power performance the MJ/2SC combo is unbeatable for transient peak power,just see the specs for yourself. So make sure you get 2SC5200 from ON semi (formerly motorola). But I think you need the pnp version too ? You can use BD139 but I think spec wise MJE15034 is similar in peak power performance.Still you have to compare their Vce maximum. As to making amp2 sound more audiophile ...make yourself a tube preamp and maybe add a tube buffer to the cd player. |
#3 |
I've used the lme49811 with great success at similar power levels. Look for a thread called national opamp inflation, also parson thread in the chip amp forum. He has some good boards for sale. this chip was designed by some pretty smart folks. Make the design modular that separates the output stage from the front end, then you can build one of each front ends and compare for yourself.
Ken |
#4 |
I cannot say what is better, but I would use a power supply NOT More that 35-0-35 V if only a pair of Output transistors is in use, in order to not go over SOA limits with a 4 ohm load. Read the very good notes on the ESP article.
About the VBE transistor, if you want you can mount it together with the DRIVERS heat sink if you make a P3A, since this is a CFP topology. Mounting it on the Output (i.e 2SC2500) heat sing will not work well in this configuration. Then I never heard ONsemi/motorola doing 2SC5200, but they make by sure several very good transistors in that range (i.e MJL1302 / MJL3281).
@Audio |
#5 |
What about thermal compensation in the project 3 amp is it needed?
How does its sound quality compare to the tda7294? What has higher thd and noise, lm4702 vs rod elliott amp |
#6 |
| LME 49713 + LME 49600 pre amp | klewis | Chip Amps | 16 | 4th February 2011 01:15 PM |
| Lamp for Rod Elliott ESP#22 Wein Bridge Osc? | lgreen | Solid State | 1 | 5th August 2007 04:11 AM |
| Fixed line level BSC based on Rod Elliot's circuit | arjscott | Multi-Way | 10 | 8th November 2006 05:57 AM |
| Rod Elliott on GainCard and others | millwood | The Lounge | 86 | 14th July 2003 11:42 AM |
| DAC, project 85 of Rod Elliott | tschrama | Digital Source | 22 | 25th January 2002 12:27 AM |
| Page generated in 0.08670 seconds (83.73% PHP - 16.27% MySQL) with 10 queries |
