Greetings (again),
Just a quick one: is there any simple way of converting a normal, split-supply amp, to work with a single-supply? From my fiddlings in LTspice, it seems to be only a matter of providing an adequate mid-supply voltage to the input reference, but there might be implications i'm not entirely aware of... Hence my request for input from brighter minds ![]() Yes, i AM aware of the inevitable output capacitor, but that's beside the / my point. |
#2 |
Yes, Khron, that works fine and is quite practical.
There are advantages to this topology - one of them guaranteed speaker protection - but you should note that lag compensation needs to be increased about 50% over a split supply. Hugh |
#3 |
Ok, so far so good
Now, the amplifier in question is a slightly modded "Load-invariant" as per Dr. Self. Due to the low DC input impedance, i had to "offset" the resistive divider that gives the input bias voltage (6.8k from V+ to "mid", and 10k from "mid" to ground. Might there be some slightly less... "barbaric" rules-of-thumb i could try to follow? |
#4 |
No, that's all you need..... but the fb AND input cap will now be heavily polarised (no bad thing!) so should be upgraded to approx 2/3 of the single rail voltage.
Insert a trimmer on the offset adjust so that you can adjust for perfectly symmetrical clip, that's a handy feature to maximise rail efficiency. Hugh |
#5 |
Check Quad's psu...
http://quad405.com/606schematic.pdf I've experimented with such psu on other amps and that's true that it is necessary to adjust it to get simetrical clip.....look at 606 schematic(9K1 and 10K resistors). But I suggest to bias this voltage splitter little higher. If I'm not wrong I've used 470E for R38 and R39 and transistors were MJE 15030/31.....with small heat sinks. Best regards Taj |
#6 |
It has been shown through careful measurements (Electronics World Jan 2003 - C. Bateman) that a polarizing voltage can increase the distortion from the capacitor. However, it might be a pleasant distortion
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. |
#7 |
And I also must agree with Bigun......
But this method is good if you want to use some transformer which you ,,find,, somewhere........that is the only reason when I use such psu. It is money saver..... Regards |
#8 |
It's more of a "complexity-saver"
![]() Thanks everyone for the input |
#9 |
Bigun,
Distortion gets a bad rap. It's almost a neurosis. If we talk of a musical instrument, it's harmonic profile, or timbre...... And I can assure you the 'distortion' of a polarised input cap sounds pretty good. Hugh |
#10 |
Well, on one hand, like i just mentioned, this is for a PA application, and on the other hand, LTspice says this should (?) be capable of 0.003% THD @ 10k, near full power (which it shouldn't reach anyway
), so... I think i might "have room" for some cap distortion, so to speak Mr Hugh, since i have your attention, might i be so bold as to ask you to take a peek into my other thread in this forum? |
| Using a 50v single supply (and trying to split it) with LM3886 | mudihan | Chip Amps | 47 | 9th March 2009 07:12 AM |
| printer single supply becoming split supply? | facundonu | Power Supplies | 2 | 16th November 2006 06:09 PM |
| split rail supply obtain from a single motorcycle battery? | leinahtan | Power Supplies | 5 | 30th August 2006 05:56 AM |
| How to split a single supply | cm961 | Parts | 13 | 9th October 2004 03:17 PM |
| Page generated in 0.11410 seconds (77.09% PHP - 22.91% MySQL) with 11 queries |
