Old 3rd May 2011, 11:09 PM   #1
budkor is offline budkor  United Kingdom
Question What happened ..???
Hi All
I found, and dug out this old Midi from the early 80s from the loft. It was covered in dust everywhere. I cleaned it up, hooked up to speakers and powered on. It was playing, but only one channel. The other channel was dead.
I thought maybe it need some switch cleaner on the volumne pot. I left it on with the volume down (the set was on all the time with just volume down), and one the second day, I put the volume up, it was the same, no sound from one channel. .... the third day same.. fourth day same.. but on fifth day, when I put the volume up, the both channel was working. It is all normal, and sounds great.
It's been working perfect for now for a few days - almost a week. What was wrong and what has brought this set back to working OK?
The midi is JVC DR-E31LBK and it had 5 graphic equaliser including balance and surround sound button as well. Hooked up to a 70s vintage huge Mordaunt Short MS400, it sounds amazingly good.
TIA.
Old 3rd May 2011, 11:16 PM   #2
Default Photo of the JVC midi
Here is the photo of the midi with CDP.
Old 4th May 2011, 05:49 AM   #3
h_a is offline h_a  Europe
h_a's Avatar
Old gear often has aged caps (lost their initial capacitance and/or their impedance increased by decades) that get a bit reformed during a few days (or hours) on the line. Could be your case here.
If you want to keep the JVC running at its best, it's anyway a good idea to at least change the power supply caps (ideally all electrolytics).
Hannes
Old 4th May 2011, 06:59 AM   #4
Mooly's Avatar
Intermitent balance pot maybe or relays in speaker outputs. Something "mechanical" like that is the most likely problem.
A simulation free zone. Design it, build it, test it.
What Just Happened??? MJL21193 The Lounge 18 14th January 2011 02:51 PM
OK... what really happened? MatthewS Car Audio 0 13th November 2008 03:52 AM
What happened to... mikeks The Lounge 4 21st May 2005 12:08 PM
What happened here? sjohnso Multi-Way 3 3rd April 2003 11:04 PM
Whatever happened to N.E.W.? Michael Rothacher Solid State 0 25th August 2001 10:11 PM
Page generated in 0.07272 seconds (70.32% PHP - 29.68% MySQL) with 11 queries
