Power amp, amplifier, need work - eBay (item 300553221551 end time May-06-11 16:56:31 PDT)
is it worth buying, sounds like a resistor is bad, I have no idea who's work it is but I can tell it's home made. |
#2 |
Well, one side is working so you could use it for comparison in troubleshooting the other side. I could only make out what looks like a 2N4037 TO3 at the output. And maybe the "400watts" deserves 2 question marks. The seller does have a good rating. Might not be too hard to squeeze 50 bucks worth of parts out of it if it wasn't repaired. Worth buying though I really can't say.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine |
#3 |
yeah lol I knew it was not 400 watts that is funny
#4 |
Looks like it's a kit job. Worth it for the case and transformer alone if you feel like building something modern in there
#5 |
I want to build burning amp 2 would it work for that? Looks like it might be to small
#6 |
The heatsinks look a bit small for any Class A amp.
#7 |
yeah thats what I thought, would the burning amp be good for all kinds of music I listen to everything from classical to pop to heavy metal
#8 |
Its worth it for the parts (so far). FWIW the 400w power rating is ridiculous. Class A amplifiers tend to have a small transformer size / heatsink size ratio. This should be fairly obvious given the nature of the beast. rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow |
#9 |
Personally, with modern output devices and a sensible bias, I dont think Class A makes a difference at the power level - but that's just me.
#10 |
ok got my BA_1 boards today, I have the irf 240's ordered and the 9240's what size transformer for two channels and what size caps would 600v transformer work? Need some help this will be my first amp I have ever built from start to finish
| FS- Twisted Pear Buffalo 32S Board & System New & Unused | secretriches | Swap Meet | 1 | 10th August 2009 02:17 PM |
| Modify & build out (2) Western Electric 300B / 2A3 Hammond monoblock amps & UTC LS-5 | quality sound | Tubes / Valves | 0 | 9th May 2009 03:59 PM |
| Krell KSA 80 bias & dc offset check & adjust procedure | Clouseaupte | Solid State | 3 | 9th August 2007 09:39 AM |
| DIY-AMP <ZAS> Low THD & IM high bandwith | murphy | Solid State | 18 | 30th December 2005 10:28 AM |
| Page generated in 0.10671 seconds (76.25% PHP - 23.75% MySQL) with 10 queries |
