Hi
I am building an "op-amp" from first principles. Currently I am trying to shift the DC/AC audio signal from Vs/2 to 0. I am trying to create (and understand) a voltage level shifter. I have seen a design (original 741) but I cannot understand it as it is incorporated in the diff amp stage. I know it'd be quite simple and it'd take probably one transistor and one resistor to make. Can anynone please show me a circuit that does it so I can understand it? Thanks Akis |
#2 |
Currently I am messing with "cascode" transistors, ie two or more in series, but I am not there yet
#3 |
There are basically two ways to translate an AC/DC signal to a different voltage base level:
1. convert it into a signal current, then back into a voltage e.g. cascode 2. interpose a floating voltage source e.g. Vbe multiplier If the signal is AC only, then two more ways are available: 3. use a capacitor, with either a resistor or switch on the output side 4. use a transformer, with the output side biassed to the desired voltage You could add optoisolation as a further method but this is only used when significant isolation (of voltage or ground currents) is needed. |
#4 |
Would you have any circuit examples for (1) or (2) ?
#5 |
Here is a circuit I have been experimenting with.
( Q3 and associated components is not part of the voltage shifter and only used to drive it for verification purposes ) Q2 keeps constant current on R6 so we get a constant voltage drop across R9. Test circuit : main parameters Vs=10V Vin=7V Vout=5V hfe Q1/Q2 = 150 secondary parameters Rin=220K Rout=2.2K The combination of the above parametes results in the values shown for R9 and R6. The bad thing about this circuit is its great dependency on Vs - so I cannot for example use it inside a discreet op-amp. I need to improve this, or use something completely different, that will "scale" with Vs. Any help/advice welcome |
| Level Shifter | maverick_123 | Class D | 1 | 6th November 2007 10:12 PM |
| extra transistor in level shifter | Tekko | Class D | 3 | 27th October 2007 11:32 AM |
| line voltage level | metebalci | Tubes / Valves | 2 | 1st March 2004 12:45 PM |
| Voltage level switch | JDeV | Everything Else | 5 | 4th July 2003 10:06 AM |
| Line Level, Balanced Voltage Level... | dkemppai | Solid State | 3 | 10th December 2002 11:04 PM |
| Page generated in 0.08106 seconds (72.65% PHP - 27.35% MySQL) with 11 queries |
