Old 2nd May 2011, 03:49 AM   #1
60ndown is offline 60ndown  United States
Default ok to run an older Sony 'plate' amp @ 16 ohms?
I'm doing a little subwoofer DIY, looks like i want to connect my drivers ( 2 x 8 ohms) at 16 ohms, because performance seems smoother (more controllable) then 4 ohms, so far?.
Its an older sony i sourced from a thrift store, removed the driver/box from and only want to use the amp.
http://www.amazon.com/Sony-SA-WM250-.../dp/B00026KYFS
16 ohms ok or will bring certain death to the little guy over time?
i have a new DMM and i 'think' the original driver is 6 ohm
Old 2nd May 2011, 03:55 AM   #2
sregor is offline sregor  United States
I know of no products (except for maybe old tube amps) which have a problem running higher resistance loads. So it won't be a problem.
Steve
FS/WTT: Older quality Kenwood stereo amplifier for Subwoofer Plate amp mtnickel Swap Meet 1 7th January 2007 03:22 AM
ISOBARIC 16 ohms load powered by 8 ohms Amp eddi0 Subwoofers 24 21st October 2006 03:29 PM
Speakers: 8 ohms vs. 16 ohms KT Multi-Way 2 14th April 2006 05:06 PM
anyone ever run PE 1000W plate amp at 3 ohms? derekwwww Subwoofers 1 29th July 2005 09:47 AM
T amp + 16 ohms speaker? Sushii Class D 8 7th July 2005 10:00 AM
Page generated in 0.07174 seconds (65.62% PHP - 34.38% MySQL) with 10 queries
