Groner Triple
Groner Triple
Old 3rd May 2011, 04:09 PM   #21
dadod is offline dadod  Croatia
dadod's Avatar
Originally Posted by Edmond Stuart View Post
Not necessarily, see: Rebirth of the Phoenix
E.
although this might result in somewhat reduced bias stability with unregulated power supplies.
That is what I tried to solve with CSS boostrap in proposed schematic. Did you look at it?
dado
Old 3rd May 2011, 05:54 PM   #22
Edmond Stuart is offline Edmond Stuart  Netherlands
Edmond Stuart's Avatar
Default wheels
Originally Posted by homemodder View Post
Welcome back Edmond.
Thanks.
But for how long? I'm still involved with other things (my bike electronics and increasing the income of my GF, Iron Condors? )
Re-Re invention of the wheel
Pioneer used this topology in more refined version in two or three of their exclusive no global feedback amps back in the 80s.
Oh well........
E.
http://www.data-odyssey.nl/
Old 3rd May 2011, 05:55 PM   #23
dado
Hi Dado,
I like to look at it, but where?
edit : gimme a link
E.
Old 3rd May 2011, 06:25 PM   #24
CBS240 is offline CBS240  United States
CBS240's Avatar
I believe Dado is referring to the ckt in post 2. I have used bootstrapping like this to supply the drivers in a HEC follower. This way I only need to regulate a few mA for the pre-driver stages. Works great! I plan to use a more refined version in my next proto.
All the trouble I've ever been in started out as fun......
Old 3rd May 2011, 06:38 PM   #25
Default more ways to Rome
I got it.Thanks CBS.
E.
Old 3rd May 2011, 06:44 PM   #26
dadod's Avatar
Yes that it is, thanks CBS240.
dado
Old 4th May 2011, 12:23 PM   #27
Samuel Groner is offline Samuel Groner  Switzerland
Wow, a circuit named after me ! As others have pointed out, there's is no reason for this, as it has been around for quite some time--just not with the attention it deserves, so I put it in my little paper.
Regarding replacing the CCSs with a bootstrapping arrangement: we need to carefully look at what actually limits output swing. If the small-signal stages of the amplifier are powered from a filtered/regulated supply which has lower voltage than the supply for the power transistors, the voltage swing limit will usually stem from the second stage, not the output buffer. In this case there is little reason to not just use CCSs.
Samuel
Old 4th May 2011, 12:43 PM   #28
You really dislike a bootstrapping arrangement, don't you?
Because of the electrolytics and/or old school practice?
E.
Old 4th May 2011, 01:10 PM   #29
Default bias stability
dado
Hi Dado,
Of course you can do it that way and it should work.
But despite a perfect CCS, the OPS bias level still depends on the voltage of the main (and unregulated) power supply. To what extent depends on the Early voltage of the output devices. That's why I followed a different route to stabilize the bias level of the phoenix amp.
E.
Old 4th May 2011, 01:37 PM   #30
Default phoenix bias
By the way, below the bias as function of the supply voltage.
Red: CCS
Green: Compensated bootstrap
Which of the two do you prefer?
E.
Groner TripleHide this!Advertise here!
Triple emmiter follower bogdan_borko Solid State 48 24th February 2013 03:24 PM
When modelling a triple chamber BP do I...? RobWells Subwoofers 5 25th August 2008 08:20 AM
Peavey Triple X Rewire! Help! xtjdx Instruments and Amps 1 28th July 2005 01:47 AM
The Triple Twisted Snake Blue_Max Everything Else 0 27th October 2004 08:37 AM
Switches - Dual Triple Pole, Triple Throw jackinnj Swap Meet 0 27th January 2003 07:18 PM
