Groner Triple
Groner Triple
Old 1st May 2011, 01:31 AM   #11
ostripper is offline ostripper  United States
ostripper's Avatar
Default choices ??
I am considering all possibilities for this triple instead of just using the "standard" Leach circuit. This "sub amp" will also be shared as my "PB150" with audiophile full range use as the design goal. I don't want a restricted bandwidth power stage to detract from the performance of the better modules. The only thing I most likely won't do is use the Jfet CCS , I'm a BJT "purest" (cheeep)
OS
Wanderer - my travels.... Facebook - davyjones lockre -
Old 1st May 2011, 02:06 AM   #12
dimitri is offline dimitri  United States
dimitri's Avatar
Send a message via ICQ to dimitri
choices?? simple
Old 1st May 2011, 05:13 AM   #13
ostripper's Avatar
Originally Posted by dimitri View Post
choices?? simple
Wow ! Those Russians are doing almost exactly what I propose ,
.: SibAudio :. - Усилители -> Высококачественный усилитель мощности "SIBAUDIO-B2"
thanks for link.
Old 1st May 2011, 07:52 AM   #14
dadod is offline dadod  Croatia
dadod's Avatar
Originally Posted by lineup View Post
Supertex has spice models for download:
Supertex - SPICE Models
I tried it but LTspice does not recognize it.
Old 1st May 2011, 07:54 AM   #15
lineup is offline lineup  Sweden
lineup's Avatar
A pity.
Happens to me in MultiSim, too.
There are models I never get to work.
lineup
Old 1st May 2011, 08:36 AM   #16
dadod's Avatar
This configuration could be ideal for ThermalTrak output transistors. If predriver and drivers are mounted on the same heathsink its temperature coefficient will canceled and what is left to compensate are output transistor, and that could be done quite simple.
dado
Old 1st May 2011, 01:43 PM   #17
ostripper's Avatar
This is a big issue that I have seen dealt with in various ways. Predrivers will not dissipate much more than their class A bias irregardless of load. Drivers and output device junctions will vary wildly in their dissipations depending on source and load (subwoofers especially). To put the whole deal (russian amp above) on the same heatsink , the 3 sets of junctions would directly negate 3 - mur120 (or 3 t-track diodes). A triple OPS does not just require a Vbe that compensates for just 1 junction. If you put the driver/output or just the output on the main HS , you still need a "3 Vbe". Observe the leach amp (only OP's on main HS). Vbe response will be quicker this way , but some negative coefficient must be added to the Vbe to compensate for the ambient room temperature . Some OEM's use a PTC resistor in parallel with the normal C-B resistor of the Vbe or an extra diode junction there for just this purpose.
(below 1 - APT ) is the one type of triple Vbe, using just the single device. (below 2 -luxman) is the luxman with it's 3 diodes. Both the luxman and APT have pre and driver on separate Heatsinks. The luxman's 3 diodes set the negative coefficient for the 3 junctions of the OPS and the non- coupled transistor sest the coefficient for the ambient (room temperature). The luxman will keep 60mA bias from 0C to 40C ambient easily ... superior .
OS
Old 3rd May 2011, 02:59 PM   #18
Edmond Stuart is offline Edmond Stuart  Netherlands
Edmond Stuart's Avatar
Default another invention of the wheel
Phoenix Triple?
Rebirth of the Phoenix
ETMC triple?
Bob Cordell Interview: Negative Feedback
E.
http://www.data-odyssey.nl/
Old 3rd May 2011, 03:09 PM   #19
Default bias stability
Originally Posted by dadod View Post
Depending on saturation characteristics of I2 and I3 this configuration will yeld higher output swing compared to other triplr output stages.
For best efficiency these current sources could be replaced with bootstrapped resistor loads, although this might result in somewhat reduced bias stability with unregulated power supplies.
Not necessarily, see: Rebirth of the Phoenix
E.
Old 3rd May 2011, 04:01 PM   #20
homemodder is offline homemodder  Portugal
Originally Posted by Edmond Stuart View Post
Welcome back Edmond.
Re-Re invention of the wheel
Pioneer used this topology in more refined version in two or three of their exclusive no global feedback amps back in the 80s.
Groner TripleHide this!Advertise here!
Triple emmiter follower bogdan_borko Solid State 48 24th February 2013 03:24 PM
When modelling a triple chamber BP do I...? RobWells Subwoofers 5 25th August 2008 08:20 AM
Peavey Triple X Rewire! Help! xtjdx Instruments and Amps 1 28th July 2005 01:47 AM
The Triple Twisted Snake Blue_Max Everything Else 0 27th October 2004 08:37 AM
Switches - Dual Triple Pole, Triple Throw jackinnj Swap Meet 0 27th January 2003 07:18 PM
