The first thing that comes to mind, considering it's fullrange which are usually efficient, is a Sonic Impact TA2024-based or clone therof, from, say, Sureelectronics (Ebay).
You can read about it here:- T-Amp - Class T integrated amplifier - [English]
w
w
Hello 60ndown,
What you are seeking is a bit of a question. How much power? SS or Tube? High end or "good" (both are subjective terms). DIY or ready-made? I'm trying to help with some meaningful advice - and don't want you to misinterpret my questions as "picky" (or such).
Budget??
Budget??
w
yes i have 2 SI amps already, but my friend would have to try and pry them from my cold dead hands
Hello 60ndown,
Budget??
most natural/non fatiguing sound for $100, (new or used) , i need a ready to use amp, my soldering skills are affected very negatively by too much excellent quality high potency coffee.
Try Luwak Coffee. But nothing is better than Singgalang Coffee (Yes, with it the amp will sound better too)
Check thru the Class-D and chip amp sections. There are plenty.
I'm VERY A.D.D and hate reading/searching,
a name model number or link would be very helpful
I'm very lazy and hate doing it for other people.
you should try helping people,
even though it requires effort its very rewarding
You have been offered help, but declined. You told us that you can't be bothered to search so can we just give you the answer. This is two steps removed from DIY, the main purpose of this site. First step is you don't want to build it yourself. Second step is you don't want to research it yourself. Would you like us to choose it for you, install it for you, then listen to it for you? If so, I am sure someone local to you would be willing to do this for an appropriate fee.
- Is there a 'cheap' quality sound SS amp?
