What do you think of these lateral FETs?
Old 29th April 2011, 02:58 PM   #1
GregH2 is offline GregH2  Australia
GregH2's Avatar
Default What do you think of these lateral FETs?
Lateral Mosfet (Click on the part numbers for specs and datasheet)
Anyone tried them?
Thoughts appreciated!
Greg.
Old 30th April 2011, 02:05 AM   #2
George61 is offline George61  United States
I used them to build an Elliott Sound Products P101 power amp and I am very happy with them. I am using two negative and two positive devices per channel on 70V rails. The amp has a considerable amount of power and is very neutral sounding, no coloration. The only down side is that they are no where near as a efficient as bipolar transistors.
The Exicons are basically clones of the old Hitachi 2SK1058 and 2SJ162 which were designed specifically for audio.
If you are interested in starting out with a high qualility, well designed, blank PCB check out Elliott Sound Products.
Old 30th April 2011, 02:33 AM   #3
djk is offline djk
djk's Avatar
Hafler used them in the late 80s, they worked fine.
Candidates for the Darwin Award should not read this author.
Old 30th April 2011, 03:34 PM   #4
GregH2's Avatar
Great, thanks for your replies.
George, glad to see the ESP amp lives up to expectations. I have read that article many times over trying to glean what I can.
Greg.
Old 30th April 2011, 04:53 PM   #5
GregH2's Avatar
Hmm, interesting.
If the data sheets are correct and I'm interpreting them correctly, the input capacitances of the complementary ECX10xxxx devices are exactly the same, whereas the hitachi laterals have up to 50% difference. Seems these devices are a better match?
Old 30th April 2011, 05:09 PM   #6
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Hmm, interesting.
Maybe you should try to read the datasheets again.
(might even compare them with those of BUZ900/901/905/906)
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 30th April 2011, 05:18 PM   #7
GregH2's Avatar
Ok, looked at them again and drew the same conclusion as before. What am I missing? Buz900/901 and 905/906 have different capacitances too. As do 2sk1058 and 2sj162.
Old 30th April 2011, 05:22 PM   #8
Ciss -Crss
Old 30th April 2011, 05:27 PM   #9
GregH2's Avatar
I'm sorry, you're going to have to spell ths out for me. I'm obviously wrong but I don't know how or why. I barely know what these characteristics mean.
Old 30th April 2011, 06:58 PM   #10
There's : Cgs - Cgd - Cds
Crss (r of reverse ) = Cgd
Ciss (i of in) = Cgd + Cgs.
Or,...Ciss =Crss + Cgs
Coss (o of out) = Cgd + Cds.
Or,...Coss = Crss + Cds.
For the input capacitance, only Crss and Ciss count.
None of the lateral MOSFETs, original Hitachi or afterlifes have equal input capacitance for N- and P-channels.
What do you think of these lateral FETs?Hide this!Advertise here!
How much VAS current to drive a pair of lateral FETs? Henry8 Solid State 15 13th November 2010 09:07 PM
Reduced power with lateral fets ??? Tekko Solid State 17 22nd September 2010 02:06 PM
UK: Hitachi SK1058 and SJ162 Lateral Fets ShinOBIWAN Swap Meet 16 16th April 2005 01:36 PM
UK: Hitachi SK1058 and SJ162 Lateral Fets ShinOBIWAN Parts 2 12th April 2005 09:42 AM
lateral vs vertical,P vs N Leolabs Pass Labs 3 15th February 2005 07:01 PM
Copyright ©1999-2017 diyAudio
