1. Do you know which power devices, TO-220 and larger,
which have very low SAT for power amplifier? And which power devices has NOT low dropout? The circuit I desined after a guy asked for amplifier working in single 12V supply. I use an OPA134 and output stage with voltage gain. Result is 2.04 Watt into 8 Ohm. To get twice as much power out we naturally should use 4 Ohm speakers. The dropout voltage, from 6.0V, is only 0.28V. This was acheived with MJE15030/31 MJE15030/31 seems to have low sat. 1. It it possible to make a more simple amplifier that also has rail-to-rail output?
lineup |
#2 |
Hi lineup
I think you have a good choice for output devices with R-2-R swing. On this occasion (low voltage) there is an argument for complementary-Darlingtons-with-gain. I have tried complementary Darlingtons with double bootstrap drive but this still has ~0.9V (a Vbe+Vce(sat)) dropout. The only other approach I have looked at is to use a single transistor pair (modern high gain type) with double bootstrap drive which should match your dropout performance but takes quite a bit of driver stage current (double bootstrap VAS). For just a few watts output some of the new Diodes-Zetex transistors with high gain (~100 min) at 1...2A or so might do nicely. These can dissipate around 1W or so so could be a good match. John |
#3 |
Doing some bootstrap.
Nice circuit. Zetex has some intesresting transistors. I remember I simulated a very low voltage amp using Zetex for lowest Vbe. It was like 0.45V Vbe. Actually I got a couple of 0.01V lower when running my circuit with 2SC5200/2SA1943. Which show us that 2SC5200/2SA1943 are very lowsat devices.
lineup Last edited by lineup; 29th April 2011 at 11:59 AM. |
| How do i build a 12v power supply ? | onis_uk | Power Supplies | 15 | 3rd October 2010 11:52 AM |
| Power One 12V 10A linear power supply | boywonder | Swap Meet | 0 | 11th September 2010 03:38 PM |
| portable 12v power supply | forkfingers | Construction Tips | 9 | 10th April 2010 09:27 AM |
| Computer power supply and consumer devices | rtarbell | Power Supplies | 1 | 22nd July 2006 09:30 AM |
| 12V Power Supply ? | samsagaz | Power Supplies | 10 | 4th June 2005 05:38 PM |
| Page generated in 0.07335 seconds (73.69% PHP - 26.31% MySQL) with 11 queries |
