2sc2073 2sd2061 2sa940 tell me if you know . there are hard to find here . |
#2 |
Banned
All transistors are available from Cricklewood Electronics CCTV and Electronic Components at 50p each for the 2SC2073 and 2SA940 and 90p each for the 2SD2061. Just enter the full 2Sxxxxx number into the search and you will find them.
P&P will be minimal even outside the EU. Cricklewood have no minimum order. Good Luck. |
#3 |
no man . i am too far away. i need replace ments not online shops.
thanks for your help but it didn't help.!! |
#4 |
Banned
If you order them you'll have them in 3-4 days.
#5 |
what about the money how much. tell me in dollars.
#6 |
We'd need to know what they are being used for. The 2sc2073/2sa940 are nothing special, if they don't see more than 100V you could probably substitute TIP31C/TIP32C quite happily. Likewise the 2SD2061 is nothing special - find something with same or better Vceo, same or better Ic, and similar fT.
#7 |
Jaycee is right- it is difficult to advise a replacement without knowing what it is needed for. Can you get MJE15032/15033? They seem to meet the requirements for the 2SC2073 and 2SA940 but they are faster and you may need to add small capacitors (100pF) base-collector to stop oscillations.
You might be able to use an MJE15032 for the 2SD but the MJE gain is lower so might not work. |
#8 |
Hard ?
All three for less than $5 at HB electronics in LA county, Cali Imerica.
Looks like Sponge Bob has killed another thread. |
#9 | |
For example you can use google to find both the parts you need and the "money how much in dollars" |
#10 |
MCM electronics has all 3 in stock here in America. 2sd1061 $0.61, 2sc2073 $1.50, 2sa940 $0.90.
MCM Electronics: Home and Pro Audio/Video, Security and Test Equipment |
| Hard to find transistor... | pflodin | Solid State | 22 | 21st December 2006 06:46 AM |
| WTB hard to find transistors | mmerig | Swap Meet | 1 | 24th January 2006 06:55 PM |
| Hard to find transistor... | pflodin | Parts | 2 | 2nd August 2004 07:33 AM |
| Hard to find diode... | Netlist | Parts | 7 | 4th February 2004 08:31 PM |
| Hard to find parts | guitargully | Parts | 3 | 16th January 2004 04:57 AM |
| Page generated in 0.09958 seconds (78.62% PHP - 21.38% MySQL) with 10 queries |
